Gear ratio upgrade
Old Aug 2, 2006 | 07:16 PM
kalsc's Avatar
kalsc
Gear ratio upgrade
Hi all!!!
Looking for some advice and/or experience from someone who may have gone through this.
My truck has stock 3.73's, as you can well imagine this doesn't bode well with 38 inch tires. At any rate, it was time to do my brakes (rotors and pads) front and rear as well as my ball joints. WELL!!!!! I take off my first rear wheel and what do I see, gear oil on the emergency brake shoes. UGH!
So, since I have to look at seals anyway, and should get the right gear ratio in the diffs for these tires, I figure I may as well rebuild the diffs while I'm at it.
So, the question is this. Are there any implications parts wise in going from 3.73's to say 4.56's? Do I have to change the carrier to accomodate gear sets over 4.10's?
The reason I ask is that when I went to pick up the rotors, I was asked if the ratio was 3.73 or 4.10, cause if the ratio was higher it was a different set of rotors needed. So this got me thinking, if I do rebuild the diffs and go with 4.56's, what else may need to be changed aside from the rotors?
Your help, as ALWAYS, is greatly appreciated.
Cheers!
Old Aug 2, 2006 | 08:29 PM
Kwikkordead's Avatar
Kwikkordead
Bump.
Anyone know the answer?
Old Aug 2, 2006 | 09:06 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
my only educated guess would be the fact that all SRW diesels had the 3.73, and the duallies had different ratios, most common being 4.10. the rotors on the D80 axle are EXTREMELY different from the Sterling 10.25 axle, and i should know.
but to the gearing, i dont think you need anything more than a ring and pinion, and a master rebuild kit (or whatever they call it). i would have a shop do my gearing just because it is hard to measure backlash and the gear mesh patterns. i do not have tools for that so that is why i would have it done for me, not that i am incapabe or anything. new bearings and seals are usually used.
Old Aug 2, 2006 | 09:19 PM
rebelchevy02's Avatar
rebelchevy02
strokins pretty much got it i would say, if you changed gears in your rear differential, yuo deffinetly would not hav eto change any of the brakes, i would replace all carrier/ pinion bearings, but from there out nothing changes, besides the fluid that is. Nice thing about changing gears ina full floating rear such as these, dont need to take apart brakes to change gears, although since you need to replace seals, you however will have to remove brakes. I replaced a gearset in a 1/2 ton chevy, its not a big deal so long as you have the proper tools!
Old Aug 2, 2006 | 11:17 PM
kalsc's Avatar
kalsc
Thanks guys. On another note, what ratio are people running with 38's to get the RPM back in the stock range (read: proper power band)?
It seems to me that there are specific carriers to support different gear ratio ranges. For example, Detroit locker states different diffs for 4.10 and down as opposed to 4.56 and up, hence my question, the liklihood of my needing to change my stock carrier (currently set up with 3.73's falling in the 4.10 and down category) to a different carrier to support 4.56 (or greater) is pretty high hey?
Which lends itself to the next question of who's running which ratios with 38's and how do you like it? Are 4.10's enough or are 4.56's better?
Thanks again. :-)
Old Aug 3, 2006 | 12:21 AM
jtharvey's Avatar
jtharvey
I know of at least one guy (not a member) who has 37" tires and went with 4.56 gears. As far as I know, he's pretty pleased with them. I'd imagine there is some sort of equation or online calculator that you could use to tell you what gears would bring you back in line with stock, given the tire size.
Old Aug 3, 2006 | 12:56 AM
kalsc's Avatar
kalsc
I know 4lo.com has some good calculators on it AND, according to the one, with 38 inch tires, running in overdrive (.71 for the E4OD), at 60mph with the transfercase at 1:1, it suggests I need 5:13's to get at 1932 RPM?!?!?! Is that right? 5.13's sounds a bit odd. For you guys running 38's with 4.10's and liking it, what are your RPM's in overdrive at 60 mph? (Automatics chime in).
Cheers!
PS - Anyone have thoughts on the different carrier for different gear ratio ranges?
Old Aug 3, 2006 | 06:46 PM
kalsc's Avatar
kalsc
super duper bump
