Fan speed selector problem
Old Aug 2, 2006 | 12:36 PM
PW01's Avatar
PW01
Hey all! Sorry for the "non Ford" question, but I am trying to avoid being raped by a Honda dealer. My wife has a 99 Honda Civic EX coupe. Yesterday, while on a short drive, air suddenly stopped coming out of the vents (A/C was cranked). I pulled over and checked to make sure that the A/C compressor was working (it was), when I got home checked appropriate fuses (looked fine), and tried switching the **** from on to off several times - nothing. In a weak moment of frustration, I smacked the **** - the fan now works only at its highest setting. My guess would be the switch has gone out, so I called the dealership to order a new one and was quoted $362.00. Apparently the the vent selector, temp selector, and fan speed selector are a one unit deal. Any other ideas before I replace the unit? I'm also trying to avoid the all day, $80 an hour, diagnostic process. Thanks in advance for any help!
Old Aug 6, 2006 | 07:38 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Get the whole unit from a salvage yard, and just swap it out.
Old Nov 30, 2006 | 01:09 AM
deepbass's Avatar
deepbass
1995 Ford bronco related issue: My heater also only works on it's highest setting. Anything other than high, no air will blow out the vents! What does this mean and what can i do to fix this?
Old Nov 30, 2006 | 02:50 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Blower motor resistor... $10 part for the Ford.. possibly $100 or more on the honda..
On high speed setting, the resistor is bypassed so the full voltage goes to the blower.
Usually a five or ten minute repair.
Old Nov 30, 2006 | 11:54 PM
deepbass's Avatar
deepbass
That has to be it.... Thanks "MazdaRangerGuyInSTL" i found this link
http://www.4door.com/tech_tips/tech_tip0146.htm
It matches the description of what you are saying... i will check it out soon when i get some time
