Sponsored by: Real Truck
tailgate replacement
Old Aug 1, 2006 | 01:39 PM
happyrock darrell's Avatar
happyrock darrell
Smile tailgate replacement
02 F250. I am putting a couple of scooters in the bed. I have removed the tailgate but would like to have a half gate or something 1/2 the height of OEM. The wheelbase of the scooters will fit but the overall length is too long. Any suggestions or recommendations appreciated. Darrell
Old Aug 1, 2006 | 02:03 PM
Leader's Avatar
Leader
Leave the tailgate down
Old Aug 1, 2006 | 02:30 PM
happyrock darrell
Sorry, I didn't paint the whole picture. I pull a TT, can't leave the tail gate down. Thanks for the response though.
Old Aug 1, 2006 | 03:11 PM
mizzitch's Avatar
mizzitch
You could wrap the tailgate support cables over the tailgate latch pins. This leaves the tailgate 1/3 open. (You have to disconnect the cables from the bed to get them around the latch pins on the bed.)
Old Aug 1, 2006 | 03:17 PM
happyrock darrell
Thank you. I will try that. That just might be enough space without getting into a bind.
Old Aug 1, 2006 | 03:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...must be a 5th wheel, eh? I bought one of the V style gates, but you still can't leave it full down. Wrapping it so it only goes 1/2 or 1/4 way sounds good to me so long as it's not the wheels (or something low) that keeps you from closing the gate.
Old Aug 1, 2006 | 04:45 PM
jake00's Avatar
jake00
why not use a 2x12 or 2x 10 could double as loading ramp even paint to match truck
Old Aug 1, 2006 | 09:47 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The width of truck bed is only like 6 feet, if that. To use as a loading ramp, you'd need it to be at least 10 feet long. But you COULD use it as a "tailgate" after you devised a way to mount it to the truck bed so you wouldn't lose it...and still make it easy to put on and take off.
Old Aug 2, 2006 | 01:12 AM
Fat Diesel's Avatar
Fat Diesel
Just remember you're almost at the angle where the tailgate will want to pop out doing this.
Old Aug 2, 2006 | 08:08 AM
happyrock darrell
thanks for the brain storming. Darrell
Old Aug 3, 2006 | 10:34 AM
CmprSpecial's Avatar
CmprSpecial
You could put a hose clamp around the open side of the tail gate to keep it from popping off.. That will also slow a potential thief.
Darrell Thompson
Nov 6, 2014 12:45 PM
Delta2142
6.4L Power Stroke Diesel
20
Jan 25, 2013 01:13 PM
Darrell Maryland
All Things Towing
21
Feb 23, 2008 08:24 AM
Scooter
Feb 12, 2000 12:58 PM
