Holley Jetting
Old Aug 1, 2006 | 08:30 AM
mkrog's Avatar
mkrog
Holley Jetting
I have a Holley 1850 card that I'm putting on a 351C.Edelbrock manafold,headers,and a mild cam.What jets would be a good place to start.Jets in it now are 71's
Old Aug 1, 2006 | 07:23 PM
d44hd's Avatar
d44hd
Check out this website. It gives the stock jetting for holley carbs. They are usually pretty close stock..71's are huge for that application..I run 66 primary and 72 secondary on my 390...Too rich and it will really shorten engine life..Somtimes you need to be that rich to compensate for a really wild cam.. http://www.mortec.com/carbs.htm
Old Aug 7, 2006 | 05:59 PM
kermmydog's Avatar
kermmydog
What alittude are you ? I run a 4160 Holley 600CFM and it came out of the box with .064 primary. I run .622 Maxi-Jets and could run .612s. I run at 5500 ft. This Holley is on a 460 with an Edelbrock, I run a Blk secondary spring with a quick change secondary housing. I run a Cloyes TRUE Street roller chain set ADV 4 degrees beyond TDC. You should easily beable to run .061s. I haven't played with the secondary side because towing if I need the secondaies I need the gas for power.
F-250 WARHORSE
Mar 21, 2017 10:44 PM
chillman88
Apr 28, 2015 04:37 AM
Tedster9
Jan 27, 2015 10:28 AM
debestuss
Jul 25, 2004 05:49 PM
MuchToMyDelight
Sep 28, 2003 10:01 AM
