3 Bulb Tail Lights
Everything was great but when I removed the original I discovered that while from the outside it looked like a three bulb light, inside it really only had two bulbs... and of course the new tail lights which the manufacturer said were made for my truck are meant to accommodate three bulbs. <O
</O
<O
</O
So, for the moment I just installed them and left the top bulb hole empty, but I would like to convert them to three bulbs if possible. Can I just splice the existing wires and add another bulb or will that fry the wires by pulling to much current? What problems might I run into and are there any other solutions? Please help, thanks. <O
</O
<O
</O
I’m guessing that the easiest way to add a third bulb will be to splice into the middle light's wiring which will result in both “red bulbs” lighting at the same time. My concern is that I don’t know if the wiring and fuse was “over engineered” or just designed to carry the appropriate current for the existing bulbs. Since its wired for a trailer I’d guess that I’d be OK running a couple extra bulbs but of course what happens when I’m actually towing a trailer, I couldn’t think of a worse time to completely fry the wires. So can the existing wires handle the existing bulbs, a few new ones, and a full set of trailer lights? I don’t know and I don’t know where to find out. I’d be very grateful for any advice I can get. <O
</O
<O
</O
If your '01 is like my '05...and I'd bet it is...your trailer lamps are handled by relays under the hood....they are not tied to the truck's tail lamps.
I cannot understand why the aftermarket ones would not match up in terms of the number of bulbs. (Another hand-crafted quality item from China.)
Excursions and Econolines share tallights. The difference is in the gasket that seals them to the body. Early vans had amber turn sigs in the top part (where the block off is), red stop/brake lamps and then the reverse lamps. When Ford did away with the amber turn sigs, they merely modified the molds.
If you look at my gallery, you will see that I converted my Ex to have the earlier amber turn sig van lamps. It was a bit of wiring, but I am thrilled with this mod.
My only concern with splicing in another pair of sockets is that I’m doubling the current that is normally drawn by the middle bulb.
You have opened a whole new option. How hard was it to split the turn signals from the rest of the light functions? Having worked with it already do you think it would be possible to split off just the break lights in the same manner? Looking at the aftermarket picture I provided above would you split up the light functions like you did with the Amber OEM’s? Do you think it would be strange to make the top light the turn signal and running light, the middle just brakes, and the bottom the reverse?
https://www.ford-trucks.com/forums/s...d.php?t=425399
You will need to cut the green wire on top of the column, otherwise your turn sigs will also act as stop lights. One caveat here. You will loose your trailer brake lights too. I found this out months after I did the tail light swap. I found the two relays under the hood that handle the trailer brake-turn sigs. I wired a Hoppy 48845 ahead of these relays..all works now. This unit is for adding trailer wiring to a vehicle with independent brake and turn sigs.
If you’re not into that much work…you could just double up what you have now.
In addition, you have an easy place to get a brake light only feed, that is from the wire under the dash that is designed to go to your electric trailer brake controller, or the wire going to your high-mount/third brake light.
Turn Signal only of course is available from the wires that go to your Front turn signals.
If you want to swap to LEDs, that's cool. But, I would not do that simply to avoid a potential problem. I have been running both my stop lights from a single CHMSL feed for a year with no issue.
ACTION The following current ranges must be adhered to on
the original flasher circuitry:
• Minimum rated current for the turn signal (either left or right) is 4.45A, at 12.8V and the maximum rated current is 5.06A at 12.8V
• Turn signal current draw below 2.83A at 12.8V will cause the flasher to flash rapidly
• Minimum rated current for the hazard flasher is 4.20A at 12.8V and the maximum rated current is 10.12A at 12.8V
• Any additional current load above the maximum rating must use isolation relays. Refer to (Figure 1) typical relay installation illustration.
WARRANTY STATUS: Information Only - Not Warrantable
Another solution to reduced current draw making flashers go too fast are equalizers. The equalizers are a 'false load' that fools your existing flashers into thinking there is an appropriate number of bulbs hooked up. They convert electricity into heat, however and you need to be careful where they are mounted.
