Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Retrieving Engine Codes Manually
Old Jul 31, 2006 | 09:50 AM
ExplorerBob's Avatar
ExplorerBob
I used to have a pickup truck that I could slip a jumper wire on to retrieve the engine codes using the dashboard check engine light. Is this possible on the Escape? Has anyone tried this? I know Autozone will check it for free now, but I wanted to know if this method still works.
Old Jul 31, 2006 | 04:57 PM
bananaboat's Avatar
bananaboat
I don't think so. There is a sequence that will display lots of data via your odometer (fuel pressure, checks lights/gauges, etc) but it won't display the codes.
Old Aug 19, 2006 | 10:18 AM
projectSHO89's Avatar
projectSHO89
OBD-II scan tool required. CAN version if 04 or newer. If you go to AutoZone, make certain the idiots there know they need a CAN-capable scanner if you're 04 or newer.
Steve
Old Aug 19, 2006 | 07:28 PM
bananaboat's Avatar
bananaboat
Plus, no-feature OBDII scanners can be found for under $40 and CAN-capable under $50. Of course you can spend much more depending upon capabilities.
cassenbl
Apr 7, 2015 12:33 PM
derek4343
2009 - 2014 F150
Dec 29, 2013 10:51 PM
MTEPERA
Nov 7, 2010 08:47 AM
pmasley
Apr 6, 2006 10:13 PM
seagull369
Computer Chips & Tuners
Jul 1, 2003 10:43 PM
