Sponsored by: Auxito
Front end knock?
Old Jul 30, 2006 | 12:05 AM
93RangerXL4x2's Avatar
93RangerXL4x2
Front end knock?
My 98 has like a rubbing knock in the front end when i drive sometimes could it be the ball joints or something along thoses lines
Old Jul 30, 2006 | 09:58 AM
93RangerXL4x2
I need to know
Old Jul 30, 2006 | 06:05 PM
bigdaddyII's Avatar
bigdaddyII
We need more info. Does the noise occur when hitting a bump, or just cruising along? Are any bumps or shakes felt in the steering wheel after you hit a bump?
Old Jul 30, 2006 | 06:53 PM
ksuroper's Avatar
ksuroper
If it is the ball joints then you have one out pretty bad. You just need to jack the truck up and check them. I had a top one out pretty bad and it would do what you describe.
Old Jul 30, 2006 | 08:32 PM
93RangerXL4x2
I dont belive its in the stering more when im makeing a slow move as i hit bumps i hear the knock it dark now i well check tommorow after work look under the front what would I be looking for? how do i know if ball joints are bad?
cleaningbug94
Nov 8, 2010 10:04 PM
fishandgame
May 5, 2009 05:52 PM
ph1946
Mar 29, 2008 04:34 PM
350z
Sep 19, 2006 09:17 PM
