knock, knock
Old Jul 29, 2006 | 06:40 PM
chopper_53e's Avatar
chopper_53e
knock, knock
My truck overheated and blew the upper radiator hose. After I fixed the hose, and filled it back up, I started it and now it has a bad knock. How would it overheating cause it to knock? Has anyone seen this before?
Old Jul 31, 2006 | 09:17 AM
Kemicalburns's Avatar
Kemicalburns
it probably melted a piston ring or threw a bearing. happens
can you isolate the knock. take a broom stick to the engine block and listen thru the other end while the motor is running ( watch the fan and other moving parts) the stick will act as a stethescope. whats your oil pressure at,
