Front end troubles
Old Jul 29, 2006 | 05:41 PM
bacressey's Avatar
bacressey
Front end troubles
I have a ’98 Navigator 4X4 with 117,XXX miles on her.
I have a humming noise coming from the front end. The noise is consistant when turning. I mostly hear the humming at speeds above 30. The closest that I can describe the noise to, is that it sounds like I have off road tires on it.
I was hoping that it was the front brakes, possibly a warped rotor. However, after installation of new rotors and pads the sound is still present.
While the truck was on the lift, I did notice that the front passenger tire had a difficult time making a full rotation without significant resistance every quarter turn.
That makes me think that the problem is the hub/bearing, or a bad cv axle.
Before I start ripping everything apart, I want to consult with other ford owners.
Thank you for any help,
Brandon
jeff2011
Sep 7, 2009 10:54 PM
FFemt5287
Jan 2, 2009 12:42 PM
FLORESH
2004 - 2008 F150
Jan 6, 2008 05:45 PM
67Duffy
Sep 15, 2007 03:21 AM
snagnever
1997 - 2003 F150
May 13, 2004 10:35 PM
