HELP..truck dies
Old Jul 28, 2006 | 10:33 PM
morodder's Avatar
morodder
Smile HELP..truck dies
i have a 1989 f150. when i turn on a/c it dies. as long as you compinsate using the gas pedal it wheel keep running.i ran codes there was no codes. i put a new map sensor on it did not help. the a/c pump is about 2 yrs. old. help will really be appreciated. thanks
Old Jul 29, 2006 | 12:07 AM
clstrfbc's Avatar
clstrfbc
Check the compressor and make sure it's not siezed up, when you turn the switch it should start spinning the inside half of the pulley.
Does the belt squeal when it comes on?
