>I use a shappie marker on the under side of the hood for
>things like filter numbers drain plug wrench size and oil
>cap.
>ie: 5.2 quarts PH8a 7/8 drain.
>Also list fireing order cause my 302 runs on a 351 fire
>order due to cam swap.
Wouldn't you have had to change your crankshaft as well? The cam shouldn't be the only reason your firing order changed.
Nope, cam makes the firing order, the 302/5.0 changed it's firing order as well, supposed to make better main bearing wear. As for records, I claim all this on my taxes & I have to keep reciepts for my rich uncle. It's just with 14 cars I hate to mix & match stuff on the ones I drive. Guess I'm out in the feild by myself on this one...
302 and 351 cranks have the pistions in the same location, so only a cam swap was needed. At the time I rebuilt the motor I know exacly what lift and duration i wanted but it was not made for the 302 and i was going to have it custom ground but found a 351 cam with .002 more lift and 1 deg of duration so in it whent.
I was wondering if the Conversion is also for 4 Wheel Drives ?
Cause I have a 1964 Ford F100 4x4. I checked out the ECI webpage and found the conversion kit, but it only says 1/2ton which I have but its a 4Wheel drive. I was wondering if it is also compatible with 4 wheels drives. Thank You
[updated:LAST EDITED ON 12-Oct-02 AT 11:44 PM (EST)]I too have wanted to put discs on the front of my 65, but when the time, and the money come, I know enough people with enough donor vehicles, that front discs are already being planned. My question is, what about the rears? I think that would be really trick, and I have heard that there were some 70s Lincolns that would work for a donor 9 inch. I wouldn't mind a steeper gear, but it can't be by too much. Any info will be appreciated.
I found this place that sells rear disc kits. www.quickperformance.com They get $199 for a kit and an additional $179 if you want an emergency brake. I don't remember if it was available in the 5x5 1/2" bolt pattern though.
Some places sell the rear disc brake conversion kits for a decent price. I have found a few places that redrill chevy rotors and make their own brackets with a hack saw so keep that in mind when you are looking around for a kit. As for the older Lincoln rear ends with disc brakes, think about the bolt pattern issue. Most of those rear ends have the 5 or 4 1/2 inch lug pattern. Keep that in mind when you are planning. Just a few more thoughts to ponder.
