headlight conversion
Old Jul 28, 2006 | 01:07 PM
jwtimme's Avatar
jwtimme
I have been looking at converting my old seald beam headlights over to a to a newer style bulb for brighter light. I'm looking at the lights in LMC but don't know what type of bulb it uses. Has anybody done this to their truck, if so do you like the new lights and were their any problems involved. I know I need headlight relays so I don't burn up my switch. Also is their anyone else manufacturing these conversion lights.
Old Jul 28, 2006 | 01:43 PM
sturzinator's Avatar
sturzinator
I converted my '68 over to the ones out of LMC. They are WELL worth it! Going from the dim yellow light to bright white light has done wonders for nightime driving. I don't know what type of bulb it is.... I think you had a choice between white or the blue xenon-type ones. Be forwarned that the wiring harness that is sold through LMC is a bit on the tight side when you wire it in.... so pay attention to how you route the wires or you'll come up short (it was close for me anyway).
Old Jul 29, 2006 | 01:17 PM
dcapshaw's Avatar
dcapshaw
I replaced my old headlamps on my '69 F100 with modern halogen hadlamps from Napa Auto for about $6 each. No other changes were required. The lights are much brighter. Of course, this doesn't change the appearance of the headlamps, which is good, or bad, depending on your preference.
Old Jul 29, 2006 | 08:43 PM
cb_murray's Avatar
cb_murray
There is a great description of this 'rewiring w/relays' job in the Articles/Spec section of this website. Check it out and let us know how it goes, as I would like to try it myself.
Old Jul 30, 2006 | 12:46 AM
ford7379trucks's Avatar
ford7379trucks
im not shur but most coposit systems use h4 bulbs. call lmc they can tell u
Old Jul 30, 2006 | 11:32 PM
Mil1ion's Avatar
Mil1ion
Maybe read this thread in the 73-79 ruck forum ?
It also applies to your truck.
https://www.ford-trucks.com/forums/s...d.php?t=513105
