"Iffy" Wipers...
Old Jul 12, 2006 | 07:41 PM
Nightrain's Avatar
Nightrain
"Iffy" Wipers...
Since I bought my 1994 F-150, I've noticed that at times, with the wiper switch turned on the first or second notch, the blades will swipe a time or two, then they'll stop until you turn the switch all the way off and on again.
Well, a few weeks ago when I delivered a car to Michigan, it started raining on me in Southern Indiana, and the wipers wouldn't come on at all... I kept ''fi-jiddlin'' with the switch, and they FINALLY came on.
I have heard of this "module" behind the glovebox that could be the culprit, but I'm also wondering if it might be the wiper motor itself??
The motor doesn't really make any noise until it's on high, and it whines pretty bad, but nothing that the radio won't drown out.
I'm trying to figure out what it is while the truck is torn down, and hopefully I can get it fixed before we shoot the paint...
Thanks for any insight!
Nightrain
Old Jul 12, 2006 | 08:12 PM
Popa Tim's Avatar
Popa Tim
If you have interval wipers, have you tried cleaning the contacts?
You can use a pen knife to lift the endcap off the lever and you'll see the screw you need to remove, then it will slide right out.
Mine does this in about the same place but I like it like that; I can then tap it with my pinky while driving and it will pulse the wipers for me...LOL
Old Jul 28, 2006 | 11:57 AM
Nightrain's Avatar
Nightrain
Sounds like a winner to me! Thanks for the info, Popa Tim!
Would the wiper motor have anything to do with this, though?
Nightrain
Old Jul 28, 2006 | 12:23 PM
quicklook2's Avatar
quicklook2
also check the wiper relay by the glovebox. it is a small black box.
Old Jul 28, 2006 | 12:37 PM
Nightrain's Avatar
Nightrain
Thanks for the tip, quicklook2!
How do I test it? That might be what I hear "clicking"...
Nightrain
Old Jul 28, 2006 | 01:11 PM
4.9inline6's Avatar
4.9inline6
i am glad someone has a post going on this...i am going to follow it for a while. i am having roughly the same problem...they don't work at all but they click when i turn the ****. for some reason, the wipers have been the last on my "To fix" list....i find that if it starts to rain, if you speed up, the rain kinda blows off..... if i can't fix it by peeping in on this thread, ill start my own. i don't want to be a thread stealer! good luck.
chris
Old Jul 28, 2006 | 01:36 PM
Nightrain's Avatar
Nightrain
Join right in, bud! This seems to be an all-to-common problem with these trucks. At least it's nothing more serious...
I'm going to check into that "black box" next time I'm at the shop where my F-150 is getting her face-lift at.
Nightrain
