what intercooler?
Old Jul 27, 2006 | 11:37 PM
cowboy49's Avatar
cowboy49
what intercooler?
moving to arizona and i want to run cooler so far all i see is the banks techni cooler and hypermax intercooler, which would you use and are there and othe brands or options
96 f250 psd sc,lb 4" exhaust 3" dp banks turbo, k&n intake
Old Jul 29, 2006 | 11:50 AM
barebackjake's Avatar
barebackjake
hypermax over the banks.
ive ran the hypermax in my rig but am going to the spearco intercooler sold by blackclouddiesel and dieselinnovations.
if you get the spearco you will have to make a pipe kit or have one made for you. its pretty simple to have some 3" mandrel bend exaust tubing bend to fit and use a EARLY 99 ypipe, v band clamp for the EARLY 99 and the reducers to go from 2-3/8 to 2"
the other way to get the pipes made is get a set of superduty pipes and get 4 3" mandrel bend 90s that you can get at most exhaust shops. and fit them all up in there and your good to go.
gtspowerstroke makes pipe kits but he is very very unreliable and has communication issues with him especially after he has your money. the last pipe kit i got from him didnt fit worth a smelly brown thing.
Old Jul 29, 2006 | 12:44 PM
1997F-350's Avatar
1997F-350
probably the cheapest would be a 6.0 or 7.3 intercooler that someone has taken off their rig. you can get em on ebay for under 200 bucks.
Old Jul 29, 2006 | 01:18 PM
barebackjake
ive got a extra 7.3 ic and a set of superduty pipes that i aint gonna use
Old Jul 29, 2006 | 03:58 PM
1997F-350's Avatar
1997F-350
you finally moved huh?
Old Aug 11, 2006 | 12:17 PM
sparkroost's Avatar
sparkroost
You can get an intercooler from a 99+ and use it. I bought all the factory tubes from Ford and some aftermarket clamps and hoses. I couldn't seem to figure out how the factory tube fit on the drivers side...so I rotated it 180 and installed it that way. It came up short about 4" so I turned out a piece of pipe at work and used it(I could have just use a piece of muffler extension). You will need to get the high torque band clamps or they will pop off from the pressure. 160,000 miles later still working like a charm. I think I paid less than 200.00 for the IC and 2 something for the tubes. Probably have 500 into it +my time, which was free, lol.
Old Aug 12, 2006 | 11:18 AM
dpatterson2005's Avatar
dpatterson2005
do you use the same plenum on the 1995 psd im in the process of installing one off a 2001 psd thanks
Old Aug 12, 2006 | 11:30 AM
sparkroost's Avatar
sparkroost
You will need the "Y" manifold. I forgot all about that. That manifold re-directs the output from the compressor to the intercooler and back to the intake manifold. I also remember having to block some port on that manifold. It's been a long time since I did it. When you sy 'plenium' do you mean the intake manifold? You have to remove the black manifold that exits the compressor and use the new style manifold. I may have had to grind something off the "Y"pipe, but I forgot already. Can't use the "powerstroke" black cover over the fuel filter housing after install either.
It's not a hard job to do. Front end has to come off. Be carefull of the radiator. I had some problems with clearance from the condensor to the radiator and from a hose or bracket that rubbed a hole in my radiator. I missed it on installation and it rubbed for years before it put a hole in the radiator. Just a small oversight.
Old Aug 12, 2006 | 12:06 PM
dpatterson2005
thanks for the info very helpful
Old Aug 12, 2006 | 09:19 PM
Dick7.3's Avatar
Dick7.3
How about the kit offered by ATS? I was looking into buying one for my 97...
Old Aug 13, 2006 | 11:11 AM
dpatterson2005
what is ats all i need is the y pipe or manifold or plenum whatever its called
Old Aug 13, 2006 | 07:45 PM
Dick7.3's Avatar
Dick7.3
ATSDiesel.com
http://atsdiesel.com/atswebsite/Prod...ntercooler.asp
Its the cheapest IC kit Ive found so far...
Old Aug 14, 2006 | 01:49 AM
1997F-350's Avatar
1997F-350
you can buy the early 99 but its over 100 bucks from the dealer. have you tried powerstrokeshop.com for there price?
y pipe..
Old Aug 14, 2006 | 07:52 AM
barebackjake
the early 99 ypipe is on national backorder ive been tryin to get one for a couple weeeks now for a buddies rig, im just gonna build one now.
the ats kit is a pretty good setup as long as your just gonna keep your stock injectors or a set of 130cc'ss its a nice clean install also.
Old Aug 14, 2006 | 05:52 PM
dpatterson2005
thanks guys for all the info im leaning toward making my own y pipe also
