Offroad & 4x4
modulator question
Old Jul 27, 2006 | 12:52 PM
smallblock351w's Avatar
smallblock351w
modulator question
okay hopefuly get some help here I have a 1980 ford f 150 4 x4 with a 351 windsor, c6 automatic and 4.11 gears. The truck originaly came with a 302 and standard trans i converted it over. The c6 was out of a 1984 ford f 250 with a 351 w and 3.50 gears
The c6 in it has been rebuilt and also has a new valve body, servo, modulator, and governor. Sometimes when you stop it doesnt like to drop down to first gear and when you start off again it will start out in secound.
Im wondering if it could be the modulator i had just gotten one from the parts store and you have to adjust it. i hear the ford ones are pre set so wondering if i should go to that? The other question is i know they go by stripes on the modulator but with gear changes and such do i just go with the modulator originaly from the c6 or ? it was a green or yellow stripe.
any help would be very very apreciated
Old Jul 27, 2006 | 04:41 PM
chrono4's Avatar
chrono4
no idea, but you might be better off in the tranny forum.
Old Jul 27, 2006 | 05:35 PM
fishmanndotcom's Avatar
fishmanndotcom
naw, just wait for monsterbaby to get on.... he is the MAN when it comes to C6's... he talked me through the rebuild of mine over the phone
on a side note.... i forgot you were in GA now, i am headed to a local mud bog this weekend. wont be anything wonderful mainly just going out to see my buddies. if you wanna come you are welcome to join me. also, i'll be in athens next weekend helping my girl move in for skool, we should get together and drink beer together!
-cutts-
Old Jul 27, 2006 | 05:37 PM
chrono4's Avatar
chrono4
thats what i was thinking, but he hadnt chimed in yet so i wasnt sure.
Old Jul 27, 2006 | 06:07 PM
smallblock351w
thanks guys ill hope to hear from him at my wits end on this one. my parents own an auto repair shop and my dads like as far as i know we have changed everything that affects the shifting.... so i refered to you all
Old Jul 28, 2006 | 12:05 AM
monsterbaby's Avatar
monsterbaby
I got your PM smallblock, and responded to it. But for others stay with the one that came on the tranny, they are more year specific than anything. I prefer the adjustable ones myself but they can be a pain to get right at first but they are more adjustable so you can get them really dialed in.
As to the not shifting into first gear at a stop, it's almost always a sticking valve in the VB, and the best advice I can give is take it out, and clean it real, real good with brake clean (this will involve tearing it down, so don't lose track of the check *****, and where they go or the springs and valves for that matter) Also check each valve and make sure they are smooth in the bores, I will even polish them a little with emory cloth, and bevel the edges just slightly but make darn sure to keep all the dust out of the valve body and clean them off real well when your done.
Also replace the filter and installing one inline in the cooler return line or as a bypass filter helps keep this problem from happening.
Old Jul 28, 2006 | 08:44 PM
F1rocco-NY's Avatar
F1rocco-NY
No expert here but had enough problems with my C6...Mostly caused by my own self...But I let a tranny sit empty of fluid for six months...Then I had to adjust the Band adjuster to 10-12lbs 1/4 turn if I remeber correctly.....Same thing was happening to me...Sometimes from a stop I would be in 1st but mostly like 2nd...I did a band adjustment and was able to spin the crap out of the tires....Worked for me...Id double check the band torque settings
Old Jul 30, 2006 | 02:41 AM
monsterbaby
band adjustment is actually 120in/lbs then back off 1-1/4 turns.
Old Jul 30, 2006 | 10:59 AM
bronco521's Avatar
bronco521
anybody think it could be linkage adjustment?c6's will take off in manual 2nd and if theres slop or worn bushings in the shifter/linkage it could cause problems.
Old Jul 30, 2006 | 11:08 AM
monsterbaby
Bronco521, I know what your saying but in this particular situation I don't believe it's linkage. Thats not to say it couldn't be in some situations but I don't beleive so here.
waystro
Jul 26, 2014 12:29 AM
46autocar
Jun 8, 2010 11:42 PM
79F-1504x4
May 28, 2010 09:39 PM
grovesr
Apr 6, 2004 07:27 AM
