Hi!
According to my "Pettersons complete book of 1973 engines". (Specs should be the same for the 1974 460.)
The 1973 Lincoln 460 had 202 HP and the cam specs were: Lift w/1.171 rockers; Intake-.442 / Exh-.486. Duration; Intake-256 / Exh-270 & overlap 36 deg.
The High Prformance versions had 244 HP & 267 HP, both had the same cam specs as follows: Lift w/1.71 rockers; Intake-.482 / Exh-.500.
Duration; Intake-270 / Exh-292 & overlap 44 deg.
Hope that helps.
burnsdl
