Headers?
Old Mar 24, 2006 | 04:05 PM
BobbyFord's Avatar
BobbyFord
Originally Posted by William
Take some wrenches, a propane torch, a can of PB Blaster and go to the junk yard, remove the right manifold from any Ford pickup with a FE motor. Closley inspect the manifold for corrosion, and cracks on the ears (where the bolts go through). After finding a good manifold have it resurfaced, install new studs. Start your truck and get the engine to operating temprature. Carefully loosen the top manifold bolts. Use lots of PB Blaster, and heat the head with the torch if the bolts are really rusted. Remove the old gasket, clean the head with acetone and reinstall the re-conditioned manifold. Torque the bolts to 10 FP. Tighten from the center bolts out.
William in Atlanta
I agree, a boneyard manifold is cheaper in the long run.
If you go with headers, you'll have to spend the extra money to have your existing exhaust pipes modified to accept headers.
Old Mar 31, 2006 | 11:48 AM
customcab66's Avatar
customcab66
I would beleave that, I gave $25 for a brand new set at a local swap meet. I am going to put them on my 390 here real soon
Old Apr 1, 2006 | 09:27 PM
Mustang Don's Avatar
Mustang Don
I disagree regarding headers. Good quality headers properly installed will last
a longggg time and give great power. I installed a set of Thorley nickel plated headers on my '66 F250/390 torquey tow motor over ten years ago and they are just fine. I went through the log manifold restoration crap for two years when I first bought my truck in '94. Now it sounds great and pulls my enclosed trailer with no problems. I did have to fabricate heat shields for the alternator and starter, but that was no biggie.
Regards,
Don Rositch
Old Apr 1, 2006 | 10:36 PM
FordBoypete's Avatar
FordBoypete
Guys, In the FWIW Department . . . . .
If y'all used OEM steel shim type exhaust manifold gaskets, like 429s or 460s still do,
instead of those composition gaskets with the steel surfaces, that insulate cast Iron from "giving up" heat to engine coolant in the head, as it is designed to do, maybe y'all wouldn't have so much hassle with cracking CI exhaust manifolds. . . . . There was a TSB on that, way back in the day, when nearly everything had a Y Block or an FE with those CI Log Manifolds, especially the Bat Wings on the PI & HO Muscle engines. . . .
FBp
Old Apr 2, 2006 | 07:18 AM
Mustang Don
When I had problems with cast iron manifolds I still had the 352 and I did
use steel shim gaskets (one of my best friends was a Ford/LM mechanic in
the sixties and he said the same regarding the heat). Problem was the
quality of the available replacement manifolds, my originals were cracked
beyond repair (pieces missing). My nickel plated headers no longer shine,
but I haven't had to touch them in ten years and I drive this truck a lot.
YMMV.
Regards,
Don Rositch
Old Apr 2, 2006 | 10:01 AM
FordBoypete
Don, I'm not dissing headers with my comment.
In many cases good headers are a great investment for lotsa' good reasons. I'm just throwing in what your friend & I both learned from "Henry & his TSBs" years ago, just incase somebody wants to know how to keep their CI Logs out of the salvage bin.
FBp
Old Apr 2, 2006 | 01:02 PM
Mustang Don
Thumbs up
No problems here either, looks like both options are covered well.
Regards,
Don Rositch
mooncricket
Jun 23, 2007 01:52 AM
mrl390
Nov 29, 2006 04:43 PM
matlock
Mar 10, 2005 11:18 AM
Hausladen
Exhaust Systems
May 4, 2004 08:03 PM
