c6 downshift problem
Old Jul 26, 2006 | 08:19 PM
smallblock351w's Avatar
smallblock351w
new governor, new servo, new modulater new valve body. and the trans doesnt always drop down to first gear when you stop. give it more gas when taking off and it will drop down to first. the kickdown is hooked up and it will drop down if your riding along and need to kick it into passing gear.
so basicaly you stop start off again and it sometimes starts off in secound gear , anyone have any thoughts or suggestions on this?
the trans never slips and has clean fluid
<!-- / message --><!-- no sigs except when logged in -->
<!-- controls -->
Old Jul 27, 2006 | 06:13 AM
smallblock351w
please any thoughts on this? only other thing ive personaly heard is to try a modulator from ford rather then from the parts store
Old Jul 27, 2006 | 07:05 AM
stuart1's Avatar
stuart1
If the engine idle is too high it can cause this or the governor is sticking.
Remove the extension housing.
The governor is held on with 4 small bolts.
There are 2 valves inside. The small one will be the culprit.
Sorry I did not see you had already replaced it.
But that is where the problem lies.
Old Jul 27, 2006 | 07:06 AM
smallblock351w
thats why i replaced it with a new governor and it still does it
Old Jul 27, 2006 | 07:08 AM
stuart1's Avatar
stuart1
New or not it still could be hung up.
Old Jul 27, 2006 | 07:14 AM
smallblock351w
okies thanks
Old Jul 27, 2006 | 09:27 AM
Big Red's Avatar
Big Red
It smells like a modulator problem to me. I had the same problem and a new Ford modulator cured the problem. I believe they are vacum activated... so is the vacum line in good shape?
Old Jul 27, 2006 | 09:48 AM
smallblock351w
aye it is i ran a brand new metal line then the rubber hose to connect it to the modulator and it defintly pulls good vacuum. i had put a modulator on but just a new one from the parts store and i didnt care for it cause its one they want you to adjust. thats why im thinking of getting one from ford
Old Jul 27, 2006 | 09:53 AM
Big Red's Avatar
Big Red
Try the Ford one... I don't think it had to be adjusted and I believe they are pretty cheap.
Old Jul 27, 2006 | 09:56 AM
SuperSnake's Avatar
SuperSnake
Your Linkage could be out of adjustment.When I had to remove my steering column I had to readjust the linkage at2-3 different points so it would shift into the proper gear.Do you have a Haynes repair manual or a chiltons it will help you adjust it out properly which my son did for me and my shifts like it should it was one of those little surprises I didn't know about with a C6
Old Jul 27, 2006 | 09:57 AM
smallblock351w
aye i have the chiltons manuel my dad owns an auto repair shop so thats where i do all the work on it =) good sugestions to thank you
Old Jul 27, 2006 | 10:14 AM
smallblock351w
one thing to note, when it does this you can drop it down manualy to first gear if you want and shift it right up through the gears
Old Jul 27, 2006 | 10:34 AM
SuperSnake's Avatar
SuperSnake
It does sound like a adjustment problem of some kind. But sometimes it could be other problems did your trans fluid smell burned?
Old Jul 27, 2006 | 10:39 AM
smallblock351w
nope always clean. change it probly every 30,000 miles as well. running out of things to check so im gonna check the linkage like you said and try a new modulator right from ford
Old Jul 27, 2006 | 10:42 AM
SuperSnake's Avatar
SuperSnake
Cool hope thats all it is.
