Sponsored by: Real Truck
Traded needed more gvwr
Old Jul 26, 2006 | 04:40 PM
ADL's Avatar
ADL
I traded my 2002 F350 4x4 srw cc sb 7.3 6sp for a 06 F350 4x4 cc chassis cab, 6.0 torque shift ,4.10 LS.
Any tips on making the 6.0 live? What milage can I expect to get?
Old Jul 26, 2006 | 05:17 PM
FortyFords's Avatar
FortyFords
Tips on making it live !!!!!!! leave it stock no chip or tuner unless you have a big wallet when warranty is denied because of it.
Quite a few guys have found out the hard way.
Keep an eye on your coolant bottle ,more than one guy has had headgasket problems with the 6.0.
Rich
Old Jul 26, 2006 | 05:25 PM
Deluxe05's Avatar
Deluxe05
As with all things automotive, routine/regular maintenance is pretty critical. And, there is a good 6.0L break-in write-up in the FAQ section.
As for mileage, are you referring to lifetime or fuel economy? There are a couple members well above the 250,000 mile mark. As for the latter, the general concensus seems to be around 13-16 city & 17-21 highway. Heavily loaded, the reported mileage figures vary quite a bit...I'd suppose that's do to the terrain, weather, wind, and drivers.
Old Jul 26, 2006 | 05:26 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The best thing you can do for a diesel is USE it ! Make it work. That keeps it clean inside
Seriously though, keep it well maintained, keep it under warranty, and don't chip it or otherwise try to get the absolute most out of it. Drive it like a diesel with a turbo. As in, not too many short stop-and-go's, don't get off the highway towing heavy and immediately shut it down and go into the diner, etc
You might want to look through the 6.0 forum's tech tips, there you will find things to do upfront, things to look for, and tricks to keeping it running a long time! It's always good to be educated about what COULD go wrong, so that you can keep an eye out for the early warnings and take care of problems before they become BIG problems.
Good luck with your new Ford! You came to the right place
Old Jul 26, 2006 | 09:10 PM
jake00's Avatar
jake00
curious as to what ya haul that the needed the higher gvwr, What type of bed do you have?
Old Jul 27, 2006 | 06:41 AM
ADL's Avatar
ADL
I haul a gooseneck trailer with a 416B cat backhoe or a 32' stock trailer. When loaded with cows the stock has more pin weight than the backhoe.
Loaded 11 grown cows on my srw and the truck was setting on the frame stops.The stock has cut of 12',12' and 8' but we had 4 baby calves that hadto go in the 8' so that put all the cows in frontof the axels. Unhooked the trailer and hooked to a 350 drw flat bed carried the load with no problem. Skirted bed with toolboxes in front of tires gooseneck hitch and reciver hitch built in.
The bed is a 9' flatbed made by Gooseneck trailers in Bryan Tx.
tbiondich
6.4L Power Stroke Diesel
17
Mar 3, 2010 01:14 PM
mudmaker
Jun 29, 2008 09:44 AM
psajunk
Jun 22, 2004 09:58 PM
Fordman 0781
Apr 29, 2004 02:36 PM
#1Truck
Aug 2, 2003 11:21 AM
