crane cam ignition problem
Old Jul 26, 2006 | 12:50 AM
LYTSPID's Avatar
LYTSPID
finally ive had my 78' 302 rebuilt,,its got edelbrock intake and holley 4 barrel carbs, next ive replace the points type ignition to a crane cams xri electronic ignition,matching it with crane cams hi-6 and lx92 coil..the problem is somtimes when i crank my engine the light on my crane cam hi-6 wont blink it stays open and the engine just wont start if it doesnt blink..if it does blink the engine would start,, ive check all the conections according to the manual and everythings fine..except for the ignition,,ive adjusted the ignition and its fine only problem is if the light on the hi-6 wont blink it means its not getting any reading inside the distributor..how can i correct this problem? is it the xri unit in the distributor thats failing sometimes? need ur advice if yuo have ,,tnx in advance..
charles jones
Nov 10, 2006 07:45 PM
pbear6969
28
Oct 22, 2006 11:52 AM
pknute
Jan 29, 2006 01:55 PM
FalconStng
21
Oct 3, 2005 03:06 PM
RCMCs 64
50
Jul 30, 2004 07:35 AM
