Glass packs?
Old Jul 25, 2006 | 09:41 PM
TopThis8899's Avatar
TopThis8899
Glass packs?
I was wondering if anyone has glass packs on there 4.9? If any of you do can you tell me how they sound and if i should put one on.
thanks.
Old Jul 25, 2006 | 10:44 PM
RotGrubestier44's Avatar
RotGrubestier44
try searching this forum for exhaust sounds first, its a FAQ, and should probably have its own sticky
Old Jul 29, 2006 | 04:03 PM
sail's Avatar
sail
I put a glass pack on my 85, Can't hardly tell it is on there. Also passed PA. inspection.
Old Jul 29, 2006 | 10:58 PM
built 80 f250's Avatar
built 80 f250
i put a thrush glass pack on my truck and the ran a 2 1/2'' pipe into it and then a 2 1/4" out and dumped it about a 12" from the back of the cab
when i originaly put it on i had a full exhaust and it was quite like the stock muffler but had a little bit more rumble with it dumping right behind the cab the exhaust is not to loud to be pulled over but when i open it up to 6000 people get outa the way
Old Jul 30, 2006 | 12:51 AM
optikal illushun's Avatar
optikal illushun
from my expereince, a glasspack on a 300 is horrific. at idle it sounded ok, just like every 300 with an exhaust but after being driven and getting on the throttle is had a very buzzy almost ricey sound. i had the shorted possible thrushpack from advance and took it right back.
on an older carburated 300 with a glasspack a friend had, it sounded like a wet fart...
Old Jul 30, 2006 | 09:43 AM
quicklook2's Avatar
quicklook2
if you took your 4.9 to 6000 rpm the noise would be the least of your problems.
picking up pieces of your engine would be the problem.
Old Jul 31, 2006 | 01:49 AM
OrdoDraconis's Avatar
OrdoDraconis
i think 30 inchers sound great i have some on my 84 bronco 2 of them true duals the sound good i have heard one with 18 on there is sounded like a low flying airplane.
Old Jul 31, 2006 | 07:49 PM
built 80 f250
6000 aint to high maby u should try it
Old Jul 31, 2006 | 08:22 PM
quicklook2's Avatar
quicklook2
that is past the redline for this engine, so no, i will not try it.
Old Jul 31, 2006 | 08:23 PM
optikal illushun
6,000 is to high for most stock production engines, let alone a low revving inline 6 like the 300.
Old Jul 31, 2006 | 08:43 PM
sail's Avatar
sail
I baby my I300. And she runs her best right there. Still has all the power you need at low RPM. Plus better fuel mileage.
