Common Causes, CEL 420 Code
Old Jul 29, 2006 | 04:14 PM
fadedblue's Avatar
fadedblue
Hi Folks,
I just bought a '96 F-150 with the 300 I-6 with a 5-speed trans. It has 137,000 miles.
I'm getting a 420 code from the computer, which translates to:
Catalyst System Efficiency Below Threshold (Bank 1)
Before I go out and steal someone's cat, what are the most common causes for this code. (I've yet to do a tune up, plugs may be 2+ years old, according to notes I found in the OM)
Old Jul 31, 2006 | 07:56 AM
Silver Streak's Avatar
Silver Streak
There are no common causes, there is only one cause: a bad cat. In order for this code to set both O2 sensors must be working properly, so they can be rules out unless they have both failed and are both reading the same voltage.
Old Jul 31, 2006 | 10:35 AM
fadedblue's Avatar
fadedblue
How can I check the O2 sensors to make sure they're OK?
Old Jul 31, 2006 | 02:08 PM
Silver Streak
They both have to work for this code to set, or they both have to be bad for this code to set. If they were bad you should have codes telling you about it.
Old Aug 1, 2006 | 01:39 AM
83Van's Avatar
83Van
Code 420 = a bad cat? Hrmm... wonder if that's a little joke by some engineer telling you it's smoking too much ;-)
[sorry, couldn't resist]
Old Aug 1, 2006 | 01:44 AM
RotGrubestier44's Avatar
RotGrubestier44
LMAO x1000
IDK why, but that is the funniest thing I have heard/ read in a good long while.
Old Aug 1, 2006 | 07:55 AM
Silver Streak
Hmmm.....missed the humor in that one. The code is there so you can't pass a visual emissions test with a bad catalyst.
lildrummer420
May 21, 2011 10:25 AM
firefighter1416
Feb 13, 2010 05:30 PM
stoker420
Apr 7, 2007 01:11 PM
bws
Nov 8, 2002 09:02 AM
hawkint
Sep 7, 2000 01:28 AM
