Truck will not start
Old Jul 25, 2006 | 08:26 PM
sledge 99's Avatar
sledge 99
Ford 300 inline 6. I have replace the ignition module and pickup coil inside the distributor. Also, replaced the relay, coil and solanoid. Truck will turn over but will not get any fire. After I replace the ign mod truck started and ran fine. Next day same problem. I then replaced the pickup coil. Same thing, started couple of times and ran fine, then nothing. Is there anything else in the distrib that could be bad? Should I just replace the distrib? When the truck starts and runs for a few min, the check engine light comes on and all the power is zapped. after that, it will not start. Anybody got any suggestions?
Old Jul 25, 2006 | 08:58 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Sounds like the same thing that happened to me, if i remember correctly i replaced the Fuel pump relay, and the pickup coil is the dizzy.
Old Jul 25, 2006 | 10:06 PM
300I6VAN85's Avatar
300I6VAN85
Talking
Sledge. Ya might get better results if you state the year of your rig. They are not all the same.
Old Jul 26, 2006 | 08:00 AM
sledge 99's Avatar
sledge 99
Sorry, 300I6VAN85. Truck is 1989 5 speed EFI. Ford 150/428/dud, I replaced the pickup coil already. Could the fuel pump relay cause the intermittent problem? Where is the fuel pump relay located. If it is one of the two 1.5 " square plastic relays on the drivers side firewall, I have replaced them.
