Misfires only at a Stop
I want to know why my 2000 V10 w/ 112,xxx miles misfires at every stop light. This misfire shakes the whole truck. This only happens when i'm D-Drive. When in Park it misfires a little less then in drive. SES light is off. Would this have to do with COP's. Please advise. I"m going nuts and don't know the problem. I guess I can try to answer my own question. Bad COP's.
One thing, if the light is not on, it won't throw a code, so a newbie code-reader-guy will not see any codes and say "there's nothing wrong". They have to look deeper at the misfire counters to see which cylinder is doing it.
Might be time to do the plugs? Have they ever been done?
Bad but intermitant vacuum leak ( funky rubber elboe joint connector on top left )
Sticking IAC
Bad COP
Crappy fuel or dirty fuel filter
Dirty MAF
and it could be internal problems with the 4R100 auto trans
But I would look at vacuum first, ignition second, intake third before assuming mechanical trans issues
I found this COP repair kit from Granatelli Hi Performance. They mention that Coil on plugs are fixable in reference to replacing the boot and the spring. They also mention that the Coil usually never gets damaged. This could be possible as I tested the resistance on all my coil at 0.8, which is in the range. Im guessing that boots develop cracks due to high heat evnvironment and this allows a spark leak and arcing. Contact springs rust out due to moisture in the spark plug well. My question is would this work if the coil is not bad and help the misfiring, would this stop misfiring. Thanks for the feedback.
"Rebuilding" a COP with a new boot and spring is as easy as going to the local auto parts store and buying "boots". I got them as low as $3 (jobber) each.
In terms of the coil itself never going bad, there is certainly the chance they can crack from heat, or have a winding with a break in it that only opens up when it gets hot. So, testing on the bench is not always a 100% certain test.
But you're right in that most of the time, I suspect the COP is still good, but it's the boot/spring leaking voltage back to ground somewhere instead of it going through the plug.
Also why did they use an OBDII plug,, my scanner works fine and found a fault when one or the egr tubes broke loose..Not doubting the info just seems
wierd..Thanks Ted
On edit
If the vehicle does not have Calif emissions ,and is above the weight class you are correct,But I haven't ever worked on a vehicle without calif emissions reqd in NY anyway
The misfire counters are there they must be accessed
So the key is you have to ask does the vehicle have calif emissions on it to be sure that means
a simple way does he aft o2 sensors
or 3 o2 sensors
and a sticker on the core support for the radiator.
As far as things to look at
I would follow "Fredvons" suggestions
If the vehicle hunts for a certain Idle I'd go after the IAC circuit
Just because the cops resistance measure the same the fail or break down with heat (open winding).
Rich
Can you please qualify your comment? I am with Houndog101 here...that seems weird???It was my understanding that ALL vehicles since '96 had to be OBD-II compliant. See quote...
Some 1994 and 1995 model year vehicles do have OBD-II. If your vehicle is 1996 or newer, U.S. federal law requires that all vehicles (cars and light trucks) sold in the United States must be OBD-II compliant. This includes all domestic (Ford, Dodge, GM, etc.) and import/foreign (Toyota, Honda, etc.) vehicles.
The sure-fire way to find out if your vehicle is OBD-II compliant is to look for the standard DLC (data link connector) that all OBD II vehicles have. It will be located underneath the driver's side of the dash.
Now, if your vehicle is 1996 or newer, you definitely have OBD-II. If your vehicle is older than 1996, the presence of the DLC may or may not indicate that you have OBD-II. To verify, look under the hood for a VECI label. The VECI label will indicate whether or not the vehicle has OBD II. Sorry, I don't have a photo of the VECI label.
LINK: http://www.obd-codes.com/faq/do-i-ha...ii-vehicle.php
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
biz
Rich
If you go to the motocraft service site it explains where we get confused
Remeber some states didn't require cali emissions when purchased.
Rich
Thanks for the suggestion to visit the Motorcraft Service website. Reading the OBD System Operation Summary - Model Year 2003 pdf document has me SHOCKED!!! Holly cow...
Funny how they do not mention that info when purchasing the vehicle. I much rather have the OBD-II over the lame OBD-I for trouble shooting reasons.OBTW: I have not gone and checked my SD V10...so...still open there...
biz
