Does anyone know what this is?
Old Jul 25, 2006 | 11:13 AM
riglertke's Avatar
riglertke
Trailering
Question Does anyone know what this is?
I finally got the bed off the truck. I quickly decided that this is not a one man job unless you use a crane. I did mine the old fashion way and it sucked!
Once off I found some stuff I did not recognize.
First is a tube that is coming from the brake lines. I have a electric brake set up so I thought that that might be what it is. Any ideas?
It looks like a vacuum connector and is connectd by a rubber hose into the brake line at the arrow. I could not find a line that it would hook to.
The next thing is this
My guess is that it has to do with dual tanks but since I only have the rear it is capped off?
The third thing are the shims between the bed and the frame.
Were there ever rubber pieces between these and the frame or did it ride on these alone? They look like someone cut washers and slid them in.
Old Jul 25, 2006 | 01:00 PM
EPNCSU2006's Avatar
EPNCSU2006
The first picture is the axle vent line. The brake lines run through it or around it or something, not sure which, but I don't think the big line has anything to do with the brakes. The second one is the gas tank vent line that connects to the charcoal canister under the hood. I'm not sure why it has the extra capped off line. Not sure what is going on with the washers in the third picture.
Old Jul 25, 2006 | 01:02 PM
andym's Avatar
andym
#2 is the vent for the rear differential. It looks like it's connected to the brakes, but it's not.
You're correct on #3, and I'm not sure on #4. I don't remember anything being between the bed and the frame on my truck when I took the bed off. Could be a previous owner's work.
Old Jul 25, 2006 | 01:48 PM
bluneon's Avatar
bluneon
there are rubber peices between the frame and the bed. i had rubber pads that were sandwiched between mine when i popped off the bed. but they didn't look like the one you pictured.
Old Jul 25, 2006 | 05:40 PM
Cruiseomatic's Avatar
Cruiseomatic
My '89 has them metal washers,I've never pulled my bed off but you can see them from undernieth.
Old Jul 25, 2006 | 08:14 PM
UncleTom's Avatar
UncleTom
Very nice way to ask questions. I like the pictures. I just hope that your nails hold in the first picture.
Old Jul 25, 2006 | 08:32 PM
riglertke's Avatar
riglertke
Trailering
It isn't going to stay that way long. I was by myself so I had to rig it that way. I am going to rest it on the ground on the landscape timbers until I am ready. The extensions on the timbers are 1/2" X 7" galvanized bolts so I think they will hold. Thanks for the compliment. I figure a pic was necessary.
Old Jul 25, 2006 | 10:30 PM
frederic's Avatar
frederic
They were made both ways - metal washers and rubber washers/spacers, depending on the year, and the cab style. Why they kept going back and forth is one of those mysteries. When I did the body work on the bed of my truck since my rubbery ones were squished flat and rotted, I just left them off, and made sure I painted the touch points very well, with more coats than the rest of the frame and bed underside.
Old Jul 26, 2006 | 08:54 AM
MustangGT221's Avatar
MustangGT221
Probably because of the trucks being built in different plants....only reason I can think of...I noticed more metric bolts on my F-150 than my F-250 and they were built in two different plants.
Old Jul 26, 2006 | 09:05 AM
EPNCSU2006's Avatar
EPNCSU2006
The F150 is also much newer than the 250, right?
TxF100
Sep 22, 2012 03:53 AM
Spool&Go
203
Dec 16, 2011 08:32 AM
BACAGrizz
Nov 19, 2009 10:15 AM
modtec33
Oct 27, 2009 12:40 PM
fxstbchopper
35
Dec 1, 2008 10:23 AM
