Fluid changes - does anybody do this regularly?
Old Jul 27, 2006 | 10:37 PM
  #31
Level2's Avatar
Level2
Originally Posted by wendell borror
Someone posted earlier saying rangers don't have rack & pinion steering, I thought the newer rangers had it, I have an 04 4x4, and I thought for sure it had r p steering. I'm not gonna go out right now and look, but just wondering.
The Ranger's do have r/p steering. I had recirculating ball p/s on my F350 which is okay for heavy duty applications like that but doesnt give the precise feel like r/p does.
Old Jul 27, 2006 | 10:40 PM
  #32
Level2's Avatar
Level2
Originally Posted by ericsmith32
On my 06 i'm changing the diff and tranny at 5k with synthetic's. Will change the diff again at another 50k. The tranny at 20k-30k. If mercon couldn't withstand 20k in a 5 speed Festiva it will be interesing to see how it holds up in the Ranger.
I don't know about all Ranger's but my 04 FX4 Level II with the Torsen rear end already has synthetic fluid in it. I think the tag on the rear end says something about 40W synthetic or 10W40.....sounds a little lite but I cant remember for sure what it said other than the 40 part.
Old Jul 28, 2006 | 07:15 AM
  #33
wendell borror's Avatar
wendell borror
"O" come on Level2, you just wanted to take this opurtunity to brag about you having a torson (lucky dog) ha ha. I don't think the regular rear diff does have synthetic, at anyrate, mine does now (royal purple), and a detroit tru-trac, naa naaa naa naa !!
Old Jul 28, 2006 | 09:47 AM
  #34
Level2's Avatar
Level2
I guess I'm BUSTED!!! LOL
Old Jul 28, 2006 | 10:07 AM
  #35
RangerPilot's Avatar
RangerPilot
The regular diff comes with regular fluid. I think the Torsen has a friction modifier as well.
Old Jul 28, 2006 | 11:55 AM
  #36
monsterbaby's Avatar
monsterbaby
someone correct me if I am wrong but I think it depends on the year. the bigger trucks like F250 and up went to synthetic in 99, and I was thinking the F150s etc went to it in 01 or 02 including the ranger, I do know that my wifes expy 2003 has synthetic and I was thinking that my codrivers 04 ranger had it also (can't check as he traded it in a couple months ago)
Old Jul 28, 2006 | 12:51 PM
  #37
wendell borror
The torson doesn't use a friction modifier as it is a gear driven unit, the clutch type lsd do need a modifier. I don't know monsterbaby, I take it your talking of the rear diff. I put synthetic in mine when I swapped in my lsd. I allways asumed the factory used dino fluids. I think I'm fixen to get an education by someone.
Old Jul 28, 2006 | 12:53 PM
  #38
RangerPilot
Ah good to know.
Old Jul 28, 2006 | 01:07 PM
  #39
monsterbaby
Wendall I am talking the rear diff, easy way to tell check the owners manual it will tell you what the factory put in. and the guy that made the comment about 10w-40 I bet that is actually 75w-140 gear oil.
Old Jul 28, 2006 | 01:22 PM
  #40
wendell borror
OK, I got my manual, mine is an 04, and it says to use motorcraft SAE 80w-90 premium rear axle lubricant, all, except fx4 level 2, level 2 uses motorcraft SAE 75W-140 SYNTHETIC REAR AXLE LUBRICANT. So, as of 04, only the level 2 had synthetic.
Old Jul 28, 2006 | 01:31 PM
  #41
monsterbaby
cool to know, wonder why though. On a side note you can change any of them to synthetic but do a good job cleaning out the old first. I run synthetic in all my vehicles diffs except the race truck, and wouldn't hve it any other way.
Old Jul 28, 2006 | 01:39 PM
  #42
RangerPilot
Why don't ya run it in the race truck monsterbaby?
Old Jul 28, 2006 | 02:17 PM
  #43
monsterbaby
because at the first sign of water degradation I change it. I always change it once a year, and check it after any race that had a lot of water on the track, and sometimes I change it because it just feels like it's possibly contaimined or I feel a need to check the gears for wear. Also the truck only runs about 4 seconds at a time under power so it doesn't really get hot, and since I run full spools in both ends I don't have to worry about spider gears or locker gears. so I can't see spending the money on synthetic for as often as I change it and the little use it actually sees, remember in a year that truck probably actually gets less than 10 miles put on it, 200ft at a time.
Old Jul 28, 2006 | 02:32 PM
  #44
RangerPilot
Ahh good reason lol. Always fun, you love that truck don't ya?
Old Jul 29, 2006 | 12:21 AM
  #45
Level2's Avatar
Level2
I knew that 10w40 was way too light but I wasn't sure what it said and it was hard to read anyway cuz of the dirt and dust. But I did know it was synthetic.
