Door Rattle
Old Nov 11, 2002 | 01:15 PM
yenima38's Avatar
yenima38
Door Rattle
Hello all,
I have a '66 F100 style side. When driving my wonderfully old truck, my passenger door rattles. I am assuming its the latch mechinisim. But I was wondering about other possibilities. I can grab the door shake it when I am not driving and get the same rattle. It seems to be the latch/lock mecinisim in the door.
In addition to this I was wondering if there was anything else that might make it do this.
Randy - Just another Ford Lover
Old Nov 11, 2002 | 01:21 PM
banjopicker66's Avatar
banjopicker66
Door Rattle
Check the window felts, especially along the bottom. They tend to let the window rattle, even when it is rolled up tightly.
Old Nov 11, 2002 | 11:06 PM
taz3fan's Avatar
taz3fan
Door Rattle
open door and check hinges probly worn pins
Old Nov 12, 2002 | 07:36 AM
sgreen's Avatar
sgreen
Door Rattle
It is probably not the hinges, but more likely needs an anti-rattle kit and new door seals, that rubber gasket that surrounds the door opening. If they have never been replaced then that is most likely the cause of the rattle. My 66 does the same thing. I have all the parts just not the time to fix it. Dennis Carpenter should be able to provide all the parts needed to reseal the doors.
Scott
Old Nov 12, 2002 | 07:34 PM
William's Avatar
William
Door Rattle
Pull the inspection cover and check the steel channel that holds the window felt channel. These tend to seperate at the spot welds. Solder will cure this.
William in Atlanta
Old Nov 12, 2002 | 08:08 PM
Mr_N's Avatar
Mr_N
Door Rattle
92 Red F150
20
Feb 10, 2015 12:30 PM
jhaas63
Jul 29, 2014 08:37 AM
kuch73
Oct 1, 2007 05:59 PM
sbmp1
Apr 15, 2004 12:30 PM
Quadiquizm
Apr 14, 2003 06:46 AM
