'96 explorer starting problems
Old Jul 25, 2006 | 02:28 AM
dayleh's Avatar
dayleh
I have a '96 Explorer 4.0 that has intermitten starting problems. It seems that when the explorer's engine is hot and starts cooling down it dosen't want to start. If the Engine is cold it starts right and also if the engine is hot and you try to restart it with in about thirty minutes or so it will start again. Some time it helps to get it started if you hold the gas pedal down a little. I can get it started by spraying ether into the throttle body. I have tried replacing the fuel filter, fuel pressure regulater, and ignition coil. Any Ideas would be great. Thanks
Old Jul 25, 2006 | 05:24 AM
marragtop's Avatar
marragtop
When you turn the key to the ON position, do you hear the fuel pump prime for a second or two? If not, try replacing the fuel pump relay.
ajzalesx
Sep 5, 2015 05:13 AM
zundap750
Oct 15, 2014 04:39 PM
RKasp
Jan 5, 2014 03:29 PM
Khannink
Dec 3, 2013 08:04 PM
ramair1969
Jun 6, 2010 11:30 AM
