96 Explorer Transmission Problems
Old Oct 15, 2014 | 11:41 AM
zundap750's Avatar
zundap750
Hi all.
I'm new to the site so this is my first actual information gathering question. I have a 1996 Explorer XL 2 dr. It has the 4.0L OHV V6 and the 4R55E Transmission. I bought it used with 152,000 miles on the odometer. About a month after I bought it I noticed it sounded different. I looked down at the tach and the RPMs are up around 2500 with the overdrive engaged. I turned the overdrive off and nothing changed. I turned it back on and nothing changed. That weekend I pulled the tranny pan and filter and replaced the filter and fluid. There was the normal amount of debris in the bottom of the pan but nothing major. Now when I drive it it tries to shift into overdrive but when it does the engine bogs down and the O/D off light starts flashing. I know how to do the overhaul but I wanted to get a few opinions before I start tearing into it. Does anybody out there in Ford Enthusiast land have any idea what could be wrong .
Old Oct 15, 2014 | 04:39 PM
exranger06's Avatar
exranger06
If the OD light is flashing then it's throwing codes. Hook up a scanner and find out what the codes are (you need a scanner that can read Ford-specific transmission codes; a cheap scanner won't be able to do it) and go from there.
TulloFord
Mar 6, 2012 10:30 PM
kellymastin
Feb 17, 2012 02:38 PM
reitman
16
Sep 26, 2007 01:23 PM
qwik88
Oct 2, 2006 05:06 PM
danbb18
Dec 2, 2003 01:50 AM
