Correct Alternator
Old Jul 24, 2006 | 10:06 PM
Boltgunner's Avatar
Boltgunner
Correct Alternator
It is hot now in Houston, and I run the A/C flat out every chance I get, but I don't know if I have enough alternator to keep the charge going to the battery as well as the mucho amps the fan motor draws (wires get hot). Any suggestions as to what I should have for the size of alternator? I drove from work the other day, about 7 miles from the office to the post office, and she wouldn't crank after I shut her down. 390 2 BBL...
Old Jul 24, 2006 | 10:15 PM
Mil1ion's Avatar
Mil1ion
AFAIK, 70 amp.......
Old Jul 24, 2006 | 10:27 PM
Boltgunner's Avatar
Boltgunner
AFAIK? What or who is an AFAIK?
Old Jul 24, 2006 | 10:31 PM
Boltgunner's Avatar
Boltgunner
As Far As I Know...duh, first time I have seen this one.
Old Jul 26, 2006 | 03:44 PM
superbepro's Avatar
superbepro
Talking
Most 73-79 trucks came with either 61 or 70amp alternators, but some models were equipped with 90 and 100amp units. I retro-fitted a brand new (Bosch)100amp alternator (6.5 inch case) into my F100 (originally with a 61amp unit, 5.25" case) a few months ago with no problems.
A nice Ford feature is that all these alternators use the same voltage regulator. Only changes needed were a slightly longer belt and changing two out of the three terminals in the wiring. Now I can feel confortable with the current demands of my stereo system and fog lights, and I am seriously considering adding an A/C system soon (I also live in hot Texas-Dallas). Raul
Old Jul 26, 2006 | 03:48 PM
Mil1ion's Avatar
Mil1ion
Vans and 79 PU's could have 100 amp alternators
PU's with the contractor package got High out put alts.
Most pickups between 1973-75 could have 38,42,55,61,amp alts
78's could have 40,60 ,60 calif,70 & 90 amp alts
79's could have 40,60,65,70,100 amp alts
Old Jul 26, 2006 | 04:49 PM
seventyseven250's Avatar
seventyseven250
If the wires are getting hot from the amount of current you are drawing, you ought to consider putting in some larger wires. Could also be a sign of something not operating correctly. Ford would not have designed anything to run this way.
Old Jul 26, 2006 | 05:08 PM
superbepro's Avatar
superbepro
Talking
I forgot to mention that when I did my 100amp alternator upgrade (on '78 with 6- inline engine), I also did upgrade all cables to 2 gauge (overkill, but I found a long roll on clearance at RadioShack) and new battery gold-terminals (also on clearance).
The upgraded cables were -Battery to chassis, +battery to alternator (with a 100 amp fuse close to the battery), -battery to engine block and chassis to engine block. I think they call this the big 3 (cable) upgrade. So no cable overheating issues. Raul
Old Jul 26, 2006 | 05:49 PM
1975Ford's Avatar
1975Ford
I always check the junkyards for rebuilt or new high amp alternators.
Old Jul 26, 2006 | 06:30 PM
Mil1ion's Avatar
Mil1ion
Me too
Especially In E-series vans where most of them are put in
Old Jul 26, 2006 | 08:35 PM
Boltgunner's Avatar
Boltgunner
Any way to tell what amperage alternator I have now?
Old Jul 26, 2006 | 08:59 PM
Mil1ion's Avatar
Mil1ion
It's stamped right on the case.
Old Jul 27, 2006 | 08:34 AM
1975Ford's Avatar
1975Ford
It will be stamped on side of alternator as Mil1ion mentioned with either 40A, 60A, 65A, 70A, 75A, or 100A amp alternators. The letter A represents Amperage. It will also have other numbers and letters stamped nearby the ##A.
Old Jul 27, 2006 | 09:28 AM
73Custom's Avatar
73Custom
Originally Posted by Boltgunner
I don't know if I have enough alternator to keep the charge going to the battery as well as the mucho amps the fan motor draws (wires get hot)...7 miles from the office to the post office, and she wouldn't crank after I shut her down.
To test the alt, run engine at about 1000-1200rpm with a/c fan on high, headlights, wipers and radio on. Test the voltage across the battery terminals, should be 13 volts or more. If that tests fine, then you have another problem.
I suspect a bad starter. When the starter gets old and worn, the windings are weak and require more amperage when hot. So when the engine is good and hot, then you shut it off for 5-10 minutes, then the starter cranks slowly. But once the starter motor is cooled off, it cranks fine. My '73 390 goes through a starter every 3 years or so - but I have headers which shortens the life of the starter due to excess heat - but then again you live in Texas, lots of excess heat there too...
Marty
Old Jul 27, 2006 | 09:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hot fan motor wires are usually caused by bad connections on the wires, typically at the blower speed resistor module. Replacement connectors can be purchased from appliance dealer service departments. They are made of a special alloy specifically for heater elements in electric dryers. Do not use the standard crimp connectors from an auto parts store.
