turbo install?
Old Aug 3, 2006 | 08:02 AM
ponch37300's Avatar
ponch37300
turbo install?
I am going to be installing a van turbo, ats housing and wicked wheel in about two weeks, when everything gets here. I have searched and found some good articles but if anyone has any links to help installing this setup it would be great. I remember reading a couple weeks ago where to get the pedistal so i will try to search for that. Any additional advice or parts i am going to need, o-rings or what not? In case it matters i also will be getting my chip from jody next week and valve body from bts this week. Just trying to get as much advice as possible in advance. Thanks for your help
Old Aug 3, 2006 | 09:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Pretty much everything you need is in this article: https://www.ford-trucks.com/article/...tallation.html
Are you talking about replacing the pedestal with the non-EBV variety? I got mine from Dieselsite, but they also can still be ordered through the Ford dealer.
Old Aug 4, 2006 | 01:04 AM
lethal5point7's Avatar
lethal5point7
I installed, removed, and re-installed mine 4 times this week.. By the last time I had it down to under and hour to swap the turbo.. SAD
It's actually pretty easy if you have air tools and if your truck isn't lifted. If it's lifted like mine HAVE FUN (and let the air out of your tires)!!
Old Aug 4, 2006 | 09:33 AM
ponch37300's Avatar
ponch37300
Thanks guys. That article was just what i was looking for. I never even thought to look in the article section, still kinda new to the site. Thanks for the advice on the pedistal cookie, that was what i was looking for. Any other advice on the install or thoughts on the performance of this setup.
Old Aug 4, 2006 | 12:44 PM
cookie88's Avatar
cookie88
FTE Emeritus
With both the big housings and the wheel it may be pretty doggy until you get that chip in it. It will perform quite well afterwards.
If you use vaseline, or any petroleum jelly to hold the o-rings in during the installation (I always do), be advised that the vaseline will melt and run out of the mounting splitlines initially looking like a leak. Unless it's just pouring oil out on the ground, assume it's the vaseline and give it a day or two to clear up.
Old Aug 4, 2006 | 03:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Great advice Scott. that is the article i used to remove the turbo the first time. ive done it four times now and i probably could do it with my eyes closed. lifted truck= sitting on the engine the whole time and sore ribs the next day. oh well its all good..
and with the o-rings, make sure to replace them and do not use the stock ones no matter how good they look. most likely they will leak and you will get another chance at improving your time at removing and installing the turbo.
Old Aug 4, 2006 | 05:32 PM
ponch37300's Avatar
ponch37300
Thanks again guys. That is the kind of advice i could use since i have never taken the turbo off before. Hopefully with all the advice from this site i won't have any problems with it. One other question, i have read that with the bigger housings some recommend not using the wicked wheel. Any thoughts on weather to use the stock or wicked wheel. Thanks
Old Aug 4, 2006 | 06:17 PM
jtharvey's Avatar
jtharvey
First, I'd look to KCM Diesel for the o-rings. They're just slightly oversized, thus helping to prevent leaks in the future. Actually, they have an 11 piece turbo bolt kit that I would get, as it's got all new o-rings and new turbo hold down bolts. Link here: http://members.***.net/kcmdieselperformance/gaskets.htm
As far as using a WW with the van turbo and ATS, I would stick with the stock wheel. A guy I know (doesn't post here) did some extensive testing of a van turbo / ATS / WW combination, in every combo possible (WW/ATS, WW/stock housing, stock wheel/ATS, & stock wheel/stock housing). He found the best results from the ATS housing and stock wheel. Plus, the WW is designed to eliminate surge. But, with the van turbo and ATS housing, you will not have a surge problem. The WW does a have a little more whistle though. However, the WW does not flow as much air as the stock wheel....how can it when every other vane is approximately half the size of the stock wheel. Less vane area = less area to grab and push air.
Old Aug 4, 2006 | 08:45 PM
ponch37300's Avatar
ponch37300
Thanks jtharvey, for the link. For 28 dollars it's worth the investment. I had thought i read the stock wheel was better with the housing.
Jtharvey, i noticed in your gallery that you had to cut the lip off the exhaust housing and weld a different one on. If i get the adaptor i shouldn't have to do this modifacation right. Is there anything else about the ebpv that needs to be modified to work or is the ebpv all set up. Thanks
Old Aug 4, 2006 | 10:19 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Hey Ponch, let me know if you plan on doing the EBPV lip modification like jtharvey did. I happen to have a van EBPV that I will not be using when I put my Van turbo on. I don't know where you are from but if your from the extreme North or tow alot then I would consider it. I live in the armpit of Alabama and I only tow a 9000K TT once a month, so I have no need for it.
Old Aug 5, 2006 | 02:55 AM
jtharvey's Avatar
jtharvey
I did this because I wanted to keep my EBPV, both to help with warmup in the cold months (still gets down to single digits here) and for an exhaust brake.. The van EBPV has a smaller flange on it than what the truck one does, so I had the flange cut off of both and the truck flange welded onto the van EBPV. You are correct that if you get the adaptor from either Beans (suggested) or DI, you will not need to do any EBPV modification. The adaptor actually does away with the EBPV alltogether. If you go that route, something should also be done with the pedistal, and either eliminate the rod that activates the EBPV so it won't begin to leak oil, or get a non-EBPV pedistal from DieselSite. However, if you want to keep your EBPV, you will have to modify it like I did. It cost me right at $100 to have a local welder cut them off and have the other flange TIG welded onto the van EBPV. That's about the same price as the adaptor, but I also bought a new van EBPV which ran about $90.
Old Aug 5, 2006 | 11:19 AM
ponch37300's Avatar
ponch37300
Jtharvey...If i want to keep the ebpv i have to cut and weld like you, the adaptor doesn't work? The adaptor came with the setup i bought so i guess i will just sell that. My friend is a good welder and works at a pipe shop so that shouldn't be a problem. If i keep the ebpv can i use the stock pedistal or do i need a different one? Where did you get your new ebpv? Thanks
Old Aug 5, 2006 | 06:09 PM
jtharvey's Avatar
jtharvey
The adaptor does not work with the EBPV. It is a direct replacement for the EBPV, so they cannot work together. The 3 bolt pattern on the adapter is the same as the 3 bolt pattern on the van EBPV. Take a second look at my gallery and compare my EBPV to your adapter. I think you'll see how the adapter goes in place of the EBPV.
If you keep the EBPV the stock pedistal will work just fine. You just may have to adjust the rod length coming out of the pedistal a turn or two to be sure the butterfly is in the full open position, but that the rod does not have any tension on it. Tension on the rod might starve the turbo for oil.
I got my van EBPV from Shop Diesel. Make sure that your welder knows that this piece can see periodic temps upwards of 850* and sustained temps in the 600* range. That might affect what type of welding he chooses to do.
Old Aug 6, 2006 | 07:00 AM
ponch37300's Avatar
ponch37300
Thanks again for the help jt. I don't know how i would get anything done without everyones advice from this site.
Old Aug 6, 2006 | 02:56 PM
ponch37300's Avatar
ponch37300
Cookie mentioned that it will be "doggy" untill i get my chip put in. This may be a silly question but with a chip, intake, exhaust, valve body the truck will have more power with this turbo setup than stock, right? Thanks
