I have a PSD with a banks TURBO back 4" system. Does anyone know where I can get a stainless cat delete pipe that does not require welding. I want it to slip directly into the flanges as the catalytic converter did. Thank you for your help. I am in SoCal.
Reason: Bold Type
chata ... if you are using the Banks system I don't believe the MBRP pipe will do you much good. The MBRP pipe bolts in place of the stock converter. The banks system requires you to cut off most of the inlet pipe of the converter to install it in their system. Your best bet is probably to take some measurements and go to your local exhaust shop and have a piece cut that will fit.
