Offroad & 4x4
guinea pigs, where u at?
Old Jul 26, 2006 | 11:52 AM
Customz's Avatar
Customz
No keeding.
They sure do look cool, but I believe they are designed for rock crawlers.
What's the mog 404 rated for? Those things are heavy and often turn 40" tires.
Old Jul 27, 2006 | 03:05 PM
RotGrubestier44's Avatar
RotGrubestier44
Originally Posted by ivanribic
Another thing, not to be a negative Nancy here, but there are a LOT of new companies making unique 4x4 parts right now. That's really good news for us and really cool for parts. But what guarantee do we have that they'll be around in 10 years, 5 years or even next year? It would really suck to invest that much money and then find out they couldn't pay the bills and closed shop.
Very true. The same sort of thing happens in many industries, like the Paintball industry for example. Its usually always best to go with a company that has been around a while, or a company that deals in many diffrent industries, like Dana.
Id take a Dynatrac ProRock 60 with Dedenbear knuckles and inner C's, converted to king pins, with Longfield 300M CV axles, Yukon gearset, and an ARB over that thing, because its all proven reliability. And that other axle, the one that looks like an ox yolk, would never be under my truck. Reminds me of a welded together TTB setup.lol
Old Jul 27, 2006 | 04:32 PM
proeliator's Avatar
proeliator
I love the clearance on those, but I've been looking at them and mogs for awhile now, and I'm not convinced they'll hold up to 52"+ tires and jumps.......which is my plan for the future. That pretty much a recipe for snapping the portal boxes right off.
Old Jul 27, 2006 | 05:32 PM
fishmanndotcom's Avatar
fishmanndotcom
i hate to say it pro, but i am un-aware of anything that'll hold up to that! maybe a set of rockies with chromo shafts that have been cryo frozen or some crazy combo like that, lol. esp for a truck as heavy as yours... what was the curb weight of that thing last you checked?
-cutts-
Old Jul 27, 2006 | 05:54 PM
proeliator's Avatar
proeliator
I'm only at 6k. Thats pretty damn trim with all the reinforcing I've done, the 44"s and steel wheels. Thats the thing, you truss a rockwell and run the chromo shafts your in pretty damn good shape...its typically not ever the knuckles that are cutting loose on them, but even those you can plate. As far as mogs go the 1300u's are the ones that are the bomb but like any of the "normal" portal axles, they're great for static loads (i.e. troop/supply movement) but not so great for shock loads (minor jumps). No point in buying those bling axles if they're gonna hold you back from jumping your truck
Old Jul 27, 2006 | 06:15 PM
BroncoRoadKill's Avatar
BroncoRoadKill
By the time you spend all your money on that truck you probly coulda just bought a used monster truck cheaper.
Or just find a set of axles that they use, what do they use anyway. I want to know.
Old Jul 27, 2006 | 06:19 PM
chrono4's Avatar
chrono4
they use ZF axles, and Pro, i know an engineer that works for ZF, hes had prototypes in his garage before so he could work at home, a set could "disapear"
Old Jul 27, 2006 | 06:21 PM
fishmanndotcom
lol i heard that!
wow, 6K is pretty light for that truck!
-cutts-
Old Jul 28, 2006 | 07:57 AM
Jmudder79's Avatar
Jmudder79
Hehehe You're Nancy. Hehehe
Old Jul 28, 2006 | 09:38 AM
ivanribic's Avatar
ivanribic
Bigfoot was really the only big name monster truck to use ZF's. I talked to several guys at ZF just a few months back and they no longer manufacture the axles that Bigfoot was using. Apparently Bigfoot Inc had to do a lot of modification on the ZF axles they used also, just to make them work under the trucks.
What most of the trucks are using is Clark or Pettibone axles with Clark planetaries. They like to stick to stuff that replacement parts are plentiful for.
Old Jul 28, 2006 | 10:54 AM
Skipped_link's Avatar
Skipped_link
Just to add a little to the monster truck tech, Tom Meents (maximum distruction) is also running ZF axles, (even lighter version than Bigfoot) with a lot of reinforcement, & the most comon monster truck diff is constructed using rockwell F-106 hounsings with clark planeteries, the axle shafts are custom built units, easily obtained from SCS gear,
I've looked into this a couple times,
Old Jul 28, 2006 | 11:19 AM
chrono4's Avatar
chrono4
ivan, last time we went through st louis, we peaked into the bigfoot shop and from what i could see every one of the truck in there had zfs under them, so they must be somewhat gettable.
Old Jul 28, 2006 | 11:25 AM
  #28
ivanribic's Avatar
ivanribic
I know they still use them but they're all old axles. Find me a part number where I can order them from ZF. Pro and I have been trying for a while now. According to ZF Bigfoot hasn't purchased an axle from them in about 5 years and the model they were buying before isn't being made anymore. I assume you could get any ZF axle and fiddle with it to make it work for your application but there's probably a good reason that Bigfoot chose what they did and modified it the way they did.
Interesting info about Mentz, especially considering all the carnage his axles go through at the finals each year. He's constantly snapping wheels off but I can't tell if it's the knuckle itself giving out or if he's sheering spindle bolts.
tseekins
VetNet
Jan 20, 2015 03:56 PM
daddio360
40
Nov 25, 2007 09:59 PM
RomerB2
28
Sep 5, 2005 11:20 PM
bob hare
Virginia Chapter
Dec 1, 2004 05:58 AM
