At a loss?????
Old Jul 24, 2006 | 04:38 PM
hambonz's Avatar
hambonz
At a loss?????
I have a 2000 F-350 with 4" exhuast, guage and no other mods done to it. I was driving about 30 MPH and got a SES light, then it would go away. I would drive another 100 feet or so and it would come back on. Now this is the part where I am lost. By the time I get my reader on there is no more light and no codes. It starts right back up and drives fine for a couple of days and then comes back, with same problem. Has anybody run across this problem. Would prefer to stay away from a dealership but I need to find out what is causing this.
Old Jul 24, 2006 | 04:59 PM
Pocket's Avatar
Pocket
What kind of code scanner are you using? Most off the shelf scanners won't read diesel codes.
Old Jul 24, 2006 | 05:03 PM
hambonz's Avatar
hambonz
A borrowed predator code reader.
Old Jul 24, 2006 | 05:16 PM
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
Maybe try leaving it plugged in and when the light comes on try pullin the code.
Old Jul 24, 2006 | 06:30 PM
Uzumati's Avatar
Uzumati
Will the predator read non generic ODB II codes (> P1000)
Old Jul 25, 2006 | 08:59 AM
hambonz's Avatar
hambonz
I have the rader in the truck and have been driving it back and forth to work. So time will tell. I am not sure if it will read non generic ODB II codes?? What is P1000??
Old Jul 25, 2006 | 06:28 PM
Uzumati's Avatar
Uzumati
In the ODB II Code Set P1000 and below are considered generic (All vehicle regardless of make or model). Model specific codes such as powerstroke codes reside above that (P1001 and Greater)
Old Jul 25, 2006 | 11:07 PM
Pocket's Avatar
Pocket
Which Predator? Is it for the Powerstroke or something else? They sell different versions, so if you borrowed one that went for a different engine, then it probably won't read your codes.
Old Jul 26, 2006 | 08:58 AM
hambonz's Avatar
hambonz
My buddy has a 2002 F-350 PSD.
Old Jul 26, 2006 | 09:06 AM
Pickupmanx2's Avatar
Pickupmanx2
Check your rear diff, the speed sensor is located there, and sometimes they get metal on them, or could be low fluid, if it gets errroneous/incorrect info, it will affect the computer and the info it sends everywhere. Does your speedo do anything wacko?
Old Jul 26, 2006 | 11:10 AM
hambonz's Avatar
hambonz
My speedo has been fine. But I will check on the fluid level. Did not even think of that. Thanks! As a side note my gas economy has gone down some.
