CPS issue???
Old Jul 24, 2006 | 09:45 AM
injoy69's Avatar
injoy69
Smile CPS issue???
ok well heres the problem this weekend i went to a concert and when we left the hose truck was fine started fine ran fine...... well when we left the concert the truck would start it cranked and all the lights dingers worked fine well when i was carnking it over the speedo and tack were jumpin all over and after about a min of cranking it started.... thank gd for compression motors butya anyways i went the next day to have the batts tested because i figured i had a low battery well both tested at 550 CCA rather than 750 and the alt tested fine on the pulse test, just to elliminate all question i had it tested at 3 diff places, pep boys auto zone and krangen so it all tested fine so my question is do the batteries need t be replaced or might it be a CPS issue also no codes were thrown except the one becasue i have my wastegate unplugged :-) any help would be definatly appricated
Old Jul 24, 2006 | 10:30 AM
Uzumati's Avatar
Uzumati
Batts Deffinately 1100 amps might not be quite enuff for these
