Dead in the water !!
Old Jul 24, 2006 | 09:22 AM
originalzman's Avatar
originalzman
Hi all ,
i have a 1988 f-150 4x4 w/300 6 cylinder
while driving ,motor just shut down, i still have all the dash electronics.
and it cranks over . i have plenty of fuel and it still wont start.the motor was warm ( i mean i have been driving for about 20 min), oh and about a week ago it did the same thing only that time i was able to coast it and pop the clutch and it started. but not this time .any help would be appreciated.
Old Jul 24, 2006 | 09:59 AM
Kemicalburns's Avatar
Kemicalburns
pull codes (www.fordfuelinjection.com) may also be tfi module, when they get hot they will fail and not allow the rig to start
Old Jul 24, 2006 | 11:33 AM
MustangGT221's Avatar
MustangGT221
Sounds like the TFI module.
Old Jul 24, 2006 | 12:48 PM
87 XLT's Avatar
87 XLT
When you turn the key to run, do you hear the fuel pump/s
As mentioned, could be a bad TFI. Got spark?
Old Jul 24, 2006 | 12:55 PM
MustangGT221
Not sure if you have dual tanks or not...but could be a fuel pump problem. You'd have to check the fuel pressure at the valve on the fuel rail.
Old Jul 24, 2006 | 02:28 PM
originalzman
thanx for the info everyone , it does have two tanks,i just replaced the filter and the fuel relay , still no fix , i will try the TFI next,, i dont have access to a code reader right now the truck is stuck in a parking lot,how would i test the pump and would it be the pump that is on the frane rail?
Old Jul 24, 2006 | 02:57 PM
quicklook2's Avatar
quicklook2
spray some ether into throttle, if it starts and dies, then it is fuel pump.
if not tfi is the next best bet.
Old Jul 24, 2006 | 02:59 PM
originalzman
hey thanx again it does want to start with ether, should i replace the pump that is on the frame rail, or the one in one of the tanks?
Old Jul 24, 2006 | 03:11 PM
quicklook2's Avatar
quicklook2
the one on the frame rail is the high pressure one, the one in the tank is low pressure.
probably the high pressure pump is bad.
Old Jul 24, 2006 | 03:25 PM
originalzman
thanx on my way to the parts store !
Old Jul 24, 2006 | 03:46 PM
MustangGT221
Don't need a code reader, those are typically used on OBD-II applications...this truck is not OBD-II.
If you follow the link given above it will provide instructions on how to check for computer codes. It will blink the code through the check engine light.
