Is there a known problem with the A/C in the right rear of the excursion?
Have they had a problem with any components rubbing through or a common leaking of refrigerate. Please inform of any of the leaks that may be known.
I had the front condensor that was replaced do to my wifes fender bender with my south garage wall a race engine and yes a motorcycle. The a/c worked ok before that? (I only had it a couple weeks.) Well with the body work done by a very good body shop. The A/C quite working before we got it home. They had checked everything and tested a couple times. Found it to leak in the rear Quarter panel area. ???? There is probaly a common wear point back there.
Hi, I have an 2001 Ex and 2 summers ago I heard a hissing sound in the rear. Found that the refrigirant was leaking out. The spot was on the passenger side where(I think) the frame or leaf springs rubbed the tube through. The dealer fixed it for 150$ copay. If you have any ??'s you can email me.
