Strange judder from somewhere???
Old Jul 17, 2006 | 04:46 PM
tiopet's Avatar
tiopet
I just changed oil and filter in the auto-transmission on my 2001 Excursion Limited.
A day or two after it starts to judder when I go 50mph and 1600rpm's, it's getting worse every day.
Could it be that I used the wrong oil type? I used Valvoline ATF MaxLife DEXRON III/MERCON.
The car is 4x4 and has just passed 60000 miles.
It's supposed to be a 4R100 according to instruction book, but it says E4OD inside in the bottom.
Also tried to change the CPS to the new improved blue one, still the same problem.
Please advise me if I'm using the correct oil type?
And/or what-ever is causing this problem?
Old Jul 18, 2006 | 12:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
That is the correct oil...well...up until about a month ago!
http://cerberus.cowgod.org/tsb06-14-04.pdf
How's the fluid level?
Old Jul 18, 2006 | 06:08 PM
tiopet's Avatar
tiopet
Fluid level is normal.
Today it's been running perfectly all day. Could it be some air pockets inside after the oil change??
Old Jul 18, 2006 | 09:57 PM
koconno2's Avatar
koconno2
Are you sure the judder is not coming from the driveline or rear axle? I just fixed a similar issue on my 2000 Ex, 125K miles, 4x4, V10. Actually I had two issues before my fix. I had a axle jutter when making sharp turns into my driveway and subdivision entrance. I also had a drive line vibration between 55mph and 65mph. The vibration was most noticeable in deceleration from 70mph to 60mph and tip in would make it go away.
Well at 120k miles my first thought was U-joints. The lovely maintenance free U-joint. I pulled the drive shaft (for the rear axle) and inspected the U-joints, which all seemed to be fine, free moving with no slop. But I noticed that the spline-slip joint in the drive shaft felt dry with some noticeable slop (lash). I removed the slip joint boot, lightly lubed the splines and re-assembled. At this point I assumed the lash was acceptable but the new grease did quite the clunk from the required lash.
My pinion seal was already leaking (still leaking from shotty warranty work many years ago) so I had planned to R&R the seal anyway. I then noticed that the pinion had noticeable fore & aft movement plus up and down. Granted this movement was about 0.010” but there should not be any movement like this. The pinion bearing pre-load torque was almost nothing. I pulled the pinion yoke, seal, front bearing and crush sleeve. Replaced the crush sleeve with a new part and re-set the pinion bearing pre-load with a new pinion nut. This part of the job was a monster. I had to use some major leverage but with every ¼ turn the slop diminished and the pre-load restored. I won't bore you with the issues I had trying to install a new pinion seal. Luckily for me, the old seal was still good so I reused it, which is still leak free today. I changed the axle lube and added a new bottle of friction modifier.
End results:
- The lube added to the drive shaft slip joint fixed a clunk I had when shifting into drive.
- The proper pinion bearing pre-load fixed the driveline vibration issues and the pinion seal leak.
- The fresh friction modifier added to the new axle lube fixed the judder issue when turning sharp into my drive way and parking spots.
Hope this helps. Now I have over heating rear brakes to work on next.
Old Jul 22, 2006 | 05:45 PM
tiopet's Avatar
tiopet
It's not a driveline vibration since all u-joints and driveshafts are working perfectly. But I will dismantle driveshaft and relube just in case.
It feels almost like a misfire when driving around 50mph. Just when you slightly accelerate to maintain correct speed. Once I ease off the accelerator it's running normal again.
Checked oil level in transmission again: still normal.
Just a thought; Could it be the rear axle, since this also was changed to Valvoline Gearoil 80W-90 (I use this oil instead of 75W-140, due to our cold climate). But no friction modifier was added.
According to the ford dealership in Norway the friction modifier was not needed.
Old Jul 23, 2006 | 07:51 PM
koconno2's Avatar
koconno2
It’s been my experience that friction modifier is very important stock Ford limited slip differentials. Although you would not notice a jutter / vibration from a limited slip while driving in a straight line.
Old Jul 24, 2006 | 06:04 AM
Downriver Thunder's Avatar
Downriver Thunder
Had a similar jutter, ended up being my torque convertor.
hornychief
1997 - 2003 F150
Mar 5, 2014 11:56 AM
Tucson150
Apr 14, 2008 01:26 PM
lwabirds
2004 - 2008 F150
Feb 26, 2007 06:32 AM
naiku
1997 - 2003 F150
Jun 30, 2006 12:16 PM
FastDEW
Dec 15, 2005 09:40 PM
