Neutral Saftey Switch??????
Old Jul 22, 2006 | 05:33 PM
Old Ford Guy's Avatar
Old Ford Guy
Cool Neutral Saftey Switch??????
My "new" 1991 F-150 5.8L E4OD will NOT start without jumping the new
solenoid on the inner fender. As stupid as this seems I cannot get this truck
to start correctly. The neutral saftey switch is new also...and I do not see any
provisions for adjustments on it.
This is driving me absolutely NUTZ!!!
Old Jul 22, 2006 | 06:49 PM
tjc transport's Avatar
tjc transport
i ain't rite
unbolt the ignition switch under the column. using a small screwdriver, move the slider. if the truck starts, the ignition switch actuator cam in the top of the column is broken. it is a cheap part. only about $12 at the dealer. but a pain in the butt to put in, taking between 3 to 8 hours, depending on experience, patience, and mechanical aptitude.. and a shop or dealer usually get between $300 to $500 to do it.
Old Jul 22, 2006 | 09:23 PM
mississauga's Avatar
mississauga
Also try this. Remove the small wire from the starter solenoid (red/lt blue) Have someone turn the key to the start position and you should have 12 volts .If not there is a problem between the ignition switch and the solenoid. Check for a problem where the connectors are sitting on the inner fender on the drivers side.I had corrosion in those connectors giving me a no start condition.
Old Jul 23, 2006 | 02:38 PM
Old Ford Guy
Cool No srtar....
Thanx guys...will get on those 2 fixes tonite or Monday morning.
I'll let you know.........
Old Jul 23, 2006 | 03:22 PM
Old Ford Guy
Exclamation Hey mississauga...
...Am I testing across the solenoid, or at the the small wire from the starter
to ground???
Thanx again...
Old Jul 23, 2006 | 07:08 PM
mississauga
Test at the small wire at the starter solenoid which is usually on the inner fender near the battery if its the same as my 88. Turn the ignition start position. Remove the small wire from the solenoid and make contact with one end of your tester(test light) to this wire and the other end to ground. If working it should light up. What you are doing is seeing if 12 volts is getting to the starter solenoid to help narrow down where your problem is.
Old Jul 23, 2006 | 07:49 PM
clstrfbc's Avatar
clstrfbc
Yes you will test from the wire you want to be hot, to ground. You can probably test it without removing the wire.
Never heard of a fender mounted starter solenoid. I always get to crawl underneath.
Old Jul 23, 2006 | 08:13 PM
mississauga
My 88 has the fender mounted starter solenoid . I thought it was that way on a lot of the f-150 s. Not sure what year they stopped doing it.
Old Jul 25, 2006 | 07:46 PM
Old Ford Guy
Thumbs down OK...still no start!
Volt/Ohm meter reads ZERO during this test...I tried several grounding points to be sure.
Still nothing...tomorrow I am going underneath to look at the starter wiring just
to look for....I have no idea what...I stumped.
Old Jul 25, 2006 | 07:52 PM
Old Ford Guy
Unhappy Still not startin'.........
I have the steering column "almost" apart to check on the ignition switch under the column...had to stop for the day....way to hot & humid for me due to a new medical disorder...
I cannot find "much" info on replacing this part in either of my aftermarket repair books but I will start again in the morning!
Thanx for everyones help so far!!!
Old Jul 25, 2006 | 08:08 PM
mississauga
I tested mine to double check what I said to you to make sure it works. I attatched the alligator clip thats on the one end of my test light to the small wire we have been talking about and the other to the negative post of the battery and when I turned the key on to start it lights up.If you do not have power(12 colts) then I would think the problem is between the ignition switch and the solenoid. It should be the same colour wire at the ignition switch . You can check for power at the switch the same way only find a good ground near the ignition switch that you can use.When the lower actuator broke on my steering column the key had a real loose feel to it and it didnt feel at all normal.
Old Jul 26, 2006 | 08:27 AM
mississauga
Your 91 is a little different from my 88.I have no experience with the 91 but the concept is the same. Because you have an e4od it looks like there is another sensor but I am not 100% sure , that detects the position of the gear shift ,which may cause your problem if that were the case. It would help if you could get a wiring diagram that is specific to your year as the generic that I have doesnt provde enough information for your particular vehicle.If it helps think of a big loop. Power goes from ignition switch thru the neutral start safety switch and any other interlocks unique to your vehicle, then off to your starter solenoid. Some where there is a break in the flow. Start from the power source and systematicly work your way thru testing for power at every connector and device in the loop.Resist the temptation to start jumping around.
