Gas tank rust
Old Jul 22, 2006 | 01:21 PM
sulldog66's Avatar
sulldog66
Gas tank rust
I think the inside of my gas tank is rusted out but the outside appears to be in great condition. What would be the easy way to determine this?
Thanks.
Mark
Old Jul 22, 2006 | 01:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Pull the tank and look inside, not easy but it is the only way.
Old Jul 22, 2006 | 09:15 PM
markjw's Avatar
markjw
The benefits are well worth the hastle...Of course it's less hastle to let your tank run about empty first.Getting rid of bad gas is nearly impossible..I've done it on a few other rigs and the sight of clean gas in the filter is very comforting..I have for the past couple of days been installing a factory "between the frame rail" gas tank in my '67.(alot more involved then I anticipated)..The donor truck a '68 or '69, must have sat for a long time 'cause the inside of the tank is pretty bad.(Rust And Varnish) lots of it.Outside looks great.I have power washed the inside as well as possible a couple times hopefully it's good enough. Gonna let it hang upside down in the sun for a day or so and call it good.
Old Jul 22, 2006 | 10:22 PM
sulldog66's Avatar
sulldog66
I can only get through about 6 gallons before she shuts down due to bad gas. I think I'll drain the gas and that will tell me all I need to know. My camper special has two tanks; the main one being in the cab behind the seats. Looks pretty straight forward to remove as it is bolted in. Does anyone know where I can find a new replacement tank?
Thanks.
Old Jul 23, 2006 | 06:34 AM
my72ford's Avatar
my72ford
www.lmctrucks.com they have all the tanks for these trucks...i cleaned the tank on my 72 f100 and then took it to a radiator shop and they put some kind of sealer in it,that was in july 2004 when i rebuilt the eng /tranny. it cost $75 and have had no problems since
Old Jul 23, 2006 | 07:58 AM
R Pope's Avatar
R Pope
I posted this before, but here goes. If you live near a tank builder, for oilfield supply, take your cleaned tank there and ask them to coat the inside with some of their epoxy liner spray. Take the guage sender out, and the fuel pickup. You'll have to leave it there for a while until they have a job with a bit of the stuff left in the gun, but it's well worth it.
Old Jul 23, 2006 | 01:00 PM
BobbyFord's Avatar
BobbyFord
I got a good, clean tank from the junkyard for $25.
If your tank is not the vented type, make sure your cap vent is working.
If you have the vented evap type gas tank, check to make sure that the vent tube to the charcoal canister is clear.
Old Jul 25, 2006 | 08:19 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Those replacement caps these days are not vented and allow high pressure to build inside the tank, not good on the tank. Take a pin, heat and burn a very small hole (.006") thru the vacuum break to allow for fuel expansion when the trucks parked in the heat.
.....=o&o>.....
Old Jul 25, 2006 | 11:11 PM
BobbyFord's Avatar
BobbyFord
.....=o&o>.....
Stant offers two different caps. One is listed for "with evaporative" and the other "without". One vented, one not. Incidently, the filler pipes that go through the side of the cabs are different for vented and non.
Old Jul 25, 2006 | 11:38 PM
"Beemer Nut"
In my area you can not buy a vented cap hence hot pin poke.
I'm in the S.F. 9 bay area counties that are heavy on smog testing. Years ago I had to paint a Streetmaster and Performer Ford blue to pass the visual.
.....=o&o>.....
Old Jul 26, 2006 | 12:04 AM
BobbyFord's Avatar
BobbyFord
.....=o&o>.....
Man, I thought L.A. County was tough.
