engine hesitation
Old Jul 22, 2006 | 01:11 AM
magicbus's Avatar
magicbus
engine hesitation
I have a hesitation problem, but only on fast starts. If i ease into it, there is usually no problem, but stomping on the gas results in sputtering and even kills the engine. I started out by replacing the spark plugs because it was time anyway. Should I continue by replacing the plug wires? Could this perhaps be a carbueration issue?
Old Jul 22, 2006 | 07:06 AM
holland501's Avatar
holland501
I would look at the accelerator pump. It's either not squirting fuel at all, or not enough fuel. It might be time for a re-build kit. Good luck.
Old Jul 22, 2006 | 02:55 PM
RustyTrustyF150's Avatar
RustyTrustyF150
might check your distributor vacum advance also , late timing dont help anything .
