Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
getting a used 2001 Ford Escape
Old Jul 21, 2006 | 11:14 AM
cprems's Avatar
cprems
Talking getting a used 2001 Ford Escape
Hi guys, I am seriously considering getting a new (to me) 2001 Ford Escape XLS V6 4dr 2wd with 88,000 miles on it. I need to know what I would need to do to make this Escape up to date on maintainance before I go tearing across country in it. I am mechanically inclined and service all my other vehicles. I am thinking about changing:
Spark plugs
Oil + Filter
Air filter
Transmission oil (filter is internal and cannot be changed-correct)
Can I use synthetic tranny oil.
Are there any things that I need to check out on the vehicle that would be noticable (warning signs) for me NOT to buy this one.
All your expertize/help/input is genuinely welcome
Ian
Old Jul 21, 2006 | 12:10 PM
i1dery's Avatar
i1dery
go to the top of this page to the RECALLS/TSBs
Should give alittle insite to the year of your vehicle.
Old Jul 21, 2006 | 06:18 PM
bananaboat's Avatar
bananaboat
The tranny filter cannot be changed. Also, your owner's manual states in bold print that only plain Mercon can be used. Now Ford has announced it will be eliminating the plain Mercon standard next spring but there's lots of discussion on that since they've always said Mercon V is not compatible.
Warning signs? Drive it between 40-50mph and make sure the torque converter doesn't shudder. If it does - run!
Before changing the plugs, get some anti-seize lube for the plugs and a set of intake gaskets since you must pull the intake manifold for the back three spark plugs.
Enjoy your Escape!
Old Jul 22, 2006 | 07:51 PM
tcesni's Avatar
tcesni
If it has Continental tires on it plan on replacing them (very noisy as they age).
Old Jul 25, 2006 | 04:42 PM
jbabbler's Avatar
jbabbler
How much are they asking for it? Have you checked the color of the tranny fluid?
