1986 f-150
Old Jul 21, 2006 | 12:27 AM
jiml100's Avatar
jiml100
1986 f-150
302 v8--- new motor, old injectors. starts for a split second and dies, usually just cranks without starting. trying to figure it out any suggestions.... help
Old Jul 21, 2006 | 06:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 21, 2006 | 10:36 AM
locknkey's Avatar
locknkey
Pull the codes and then post them if its an EFI engine...although the way you describe seems like its a fuel issue, possibly mebie a fuel filter or fuel pump regulator, does the sound of the pumps come on when you turn the key on? More info is needed.
Old Jul 21, 2006 | 11:52 PM
jiml100's Avatar
jiml100
f-150
can hear the pump in the tank running, removed hose from canister filter and turned on key fuel does not pump out unless i drop line down to start it siphoning then the pump will help, should the inside tank pump push out fuel pretty good ? i can also hear the frame rail pump come on for a few seconds then stop. tryed both tank pumps they dont pump out very much fuel. also should frame rail pump , pump pretty good also. help.
Old Jul 21, 2006 | 11:59 PM
Mil1ion's Avatar
Mil1ion
You can get a testor from autozone "loan a tool" for testing fuel rail pressure.
Just hook it to the schrader valve and read the gauge.
It should be near 40 psi if both pumps work.
