8.8 axle advice req'd
Old Jul 20, 2006 | 10:35 PM
Stephan's Avatar
Stephan
Ok,
so I've got a line on an 8.8 5bolt out of a 88 lincoln with disk brakes $200.
I was wondering if it would be a direct swap into my 1992 f-150- width wise. From what I'm told the tag number is
L08A888f1 4
423f
I'm not looking to spend too much money on my f-150. Thought about d60 solid axle swaps, but I don't have the time or another vehicle right now.
Stock drive train parts are in abundance out here.
Also have a source for an Eaton E-locker for $500 (from open to full locker) for my 8.8. I thought that by having a selectable locker would be a good idea.
By having the second axle, that I could re-gear and locker; it would be a quick swap with minimal downtime. And also have spare parts in the end.
Any advice is appreciated.
Steph
Old Jul 21, 2006 | 04:25 PM
chrono4's Avatar
chrono4
im not sure if its the same width, but a quick measure could tell you. ive heard that they are, just not 100%
Old Jul 21, 2006 | 06:38 PM
aurgathor's Avatar
aurgathor
I think it won't be wide enough.
Old Jul 22, 2006 | 01:50 AM
Stephan's Avatar
Stephan
I heard the perches on that lincoln 8.8 are for airbags OR coils, which actually ain't such a bad thing. But I don't wanna screw around changing linkages and crap right now. If I'm going to go through the trouble for an 8.8, I would rather have a d60.
thanks!!
Old Jul 25, 2006 | 12:44 AM
nighthawk285's Avatar
nighthawk285
sorry for changing the subject, but where are you finding the Eaton E-locker for $500? the lowest ive found is $700
Old Jul 25, 2006 | 02:50 AM
Stephan's Avatar
Stephan
used, used, used
Old Jul 25, 2006 | 01:42 PM
kennethl6's Avatar
kennethl6
The Lincoln has air bags, it's too short, has the wrong pinion offset and the wrong wheel bolt pattern. The carrier is wrong also (28 spline to the trucks 31 spline). Forget it, find a truck 8.8 axle, there out there.
Old Jul 25, 2006 | 01:45 PM
chrono4's Avatar
chrono4
wrong pinion offset? it may have bags, but they have leafs to locat the axle
Old Jul 25, 2006 | 03:58 PM
andym's Avatar
andym
Width wise, I'm not sure on. But I do know that the bolt pattern is different and you won't be able to use your current wheels unless you re-drill the rotors.
Old Jul 25, 2006 | 04:35 PM
kennethl6's Avatar
kennethl6
The pinion along with the driveshafts on trucks are offset to the right a few inches. Cars are down the center. 88 Lincolns don't have leaf springs. The mounting bracket for the air bag is in the same position as the coil springs for the Crown Vic if you have a Town Car or the Mustang/TBird if you have a Mark7.
Old Jul 25, 2006 | 04:39 PM
chrono4's Avatar
chrono4
the offset wont matter, thats what u joints are for. i always thought that they just had super soft leafs, i thought i remembered them on my brothers 88 lincoln, musta been thinking of somthing else
Old Jul 26, 2006 | 01:11 PM
MustangGT221's Avatar
MustangGT221
The entire drivetrain on these trucks is off center...
That lincoln axle will not work...its not wide enough and like he said the offset is wrong and it's the wrong spline count.
The 8.8s come in different widths and differential locations. On our trucks, the differential is more to the drivers side....and no the u-joints will not take up that missmatch.
