ok yall, i know its been like frickin forever since ive been on...... so here i am crawlin back
ive got an 85 B2 4x4 automatic. runs awesome. four by four works great.
only problem is that its missin the emission stuff. ive got the smog pump and the cat, but everything in between is gone. any idea at least on the names of the parts? im freakin clueless on this name stuff!!
gracias
The best thing is to find one in a junkyard and rip off the complete thing. There are a ton of vacuum hoses, valves, diverter (one way exhaust) valves, etc. you will need to make it work factory correct via the carb.
I would bring masking tape and marker to tag connections. Been a while since I had/worked on my 84 B2, but, I think there were something like 24+ vacuum hose connections and the under the hood diagram did only a basic job covering them.
