Oil & Lubrication
oil pan help
Old Jul 19, 2006 | 07:38 PM
hartattack3's Avatar
hartattack3
oil pan help
i have a 95 f150 4.9 stick shift that has a leaking oil pan that needs replacing. i was told i have to jack the moor or drop the tranny to get the pil pan off. is this true? its a 2wd if that helps
Old Jul 19, 2006 | 08:41 PM
okst1's Avatar
okst1
I don't own an F150 but my chilton's says that you have to jack the engine up.
Old Jul 20, 2006 | 05:30 AM
dkstuck's Avatar
dkstuck
Yes, help a buddy years ago an we had to jack engine up, turn crank over for clearance to get pan off. Take your time, not too bad of a job. Use the pins to keep gasket in place. Good Luck
krvoorheis
2015 - 2020 F150
110
Aug 17, 2022 04:01 PM
mike potts
Sep 6, 2016 12:29 PM
andrew's64
15
Aug 21, 2016 11:17 PM
72CC428
15
Jun 5, 2016 02:08 PM
Jaime74656
20
Dec 18, 2013 07:21 AM
