Sponsored by: Kumho
Front coil spring identification
Old Jul 19, 2006 | 02:10 PM
jschluter's Avatar
jschluter
I need help from the more hard core data types concerning front coil springs on a 78 F-250 2WD P/U. The existing spring has an OD of 5.400", wire dia. of 0.665", mean coil dia. of 4.735" and 7 active coils (9 total). The top coil is open w/o an insulating rubber. The lower coil is closed and has a reduced diameter for the spring retainer. Spring rate calculators agree that the spring constant is ~370 #/in. I can't get a free length since it is still in the truck but the length at full droop is 15.75". Can anyone identify that spring by mfg., part #, etc and supply any missing data?
Data on the existing springs will be a big help in setting up the modified front suspension. I plan to lower the front end between 1-2" and will need a stiffer spring to go along with an added sway bar. And history has taught me that guessing critical data seldom yields a satisfying set-up.
nmto0777
Mar 5, 2015 10:04 AM
fun_suv
20
Feb 11, 2009 06:25 PM
GeneStoner
33
Jul 19, 2005 11:04 PM
63_ford_stepside
Jul 31, 2003 11:36 PM
Jason 88F150
Feb 21, 2003 09:32 AM
