Power drain thrugh the EEC unit
Old Jul 19, 2006 | 06:39 AM
Bergracer's Avatar
Bergracer
Hi all
My Explorer`s battery is beeing drained thrugh the EEC unit, with 0,57-2 Amp, could anybody tell me what is wrong, is the EEC to be replaced or is there a cheeper way to come over the problem.
Thanks in advance.
Mikael A
Copenhagen, Denmark
Old Jul 19, 2006 | 11:22 AM
projectSHO89's Avatar
projectSHO89
Have you determined via which fuse the current is being drawn?
Steve
Old Jul 19, 2006 | 11:47 AM
87 XLT's Avatar
87 XLT
If you're sure its the EEC, have you tried pulling the EEC relay?? might be stuck closed.
Old Jul 19, 2006 | 02:26 PM
Bergracer's Avatar
Bergracer
I determined that it is the EEC via which fuse the current is being drawn.
I havent tryed to pull the EEC relay, - but it soundt like it pulls when i put the battery on again.
Best regards
Mikael A
Old Jul 19, 2006 | 03:41 PM
87 XLT's Avatar
87 XLT
Hard to say from here, but the EEC relay should only be closed when you turn the key to start or run.
If the ignition is off & you hear the relay close when you connect the battery, try removing the connector from the ignition switch.
Does the relay click now when you connect the battery?? If it does'nt you need to replace the ignition switch.
Got a wiring diagram??
