1978 - 1996 Big Bronco
transmisson help???
Old Jul 18, 2006 | 01:16 AM
factory594x4's Avatar
factory594x4
Question transmisson help???
My 88' 5.0 aod will only shift in forward gear. No R N only OD D 1. Reverse and nuetral go forward. Is the transmission dead?
Old Jul 18, 2006 | 03:36 AM
muckypaws's Avatar
muckypaws
doesn't sound good but I'm no expert on early Broncos. I'm sure someone else will help you.
Have you checked the fluid levels? Pulled the codes? That would be the first thing to try.
Old Jul 18, 2006 | 02:15 PM
greystreak92's Avatar
greystreak92
Um, is the engine running backwards? Yeah, MOVIN at all in either of the NON-moving gears (Park/Neutral) is a problem. Are you certain you haven't suffered some sort of linkage failure? Will it go into Park and will the parking pawl engage?
Old Jul 18, 2006 | 10:05 PM
HUCKSTER-USA's Avatar
HUCKSTER-USA
AOD trans shifts by the throttle linkage. ford sold the better idea to GM (using vaccume to shift the gears) any how, this linkage looses its adjustment (just the slightest) or you loose that nylon clip that holds it together it only takes acouple miles to cook the clutches! smell the dipstick, AOD trans are junk because of this.
Old Jul 18, 2006 | 11:58 PM
greystreak92
They have a better service record than the E4OD! And being a direct descendent of the C4 I tend to disagree with the notion that they are junk.
Old Jul 19, 2006 | 12:45 AM
factory594x4
what do you mean pawl? Park works fine.
Old Jul 19, 2006 | 02:41 PM
HUCKSTER-USA
factory, your clutches are fused together,melted,cooked! lucky it even starts in park! i've seen this a bazillion time out in the mud and trails, literally drug people outta mud holes because they had no neutral and couldnt get to the driveshaft to take it off. sorry dude but its dead. rebuild and get a new torque converter cause yer gonna have pieces of clutch everywhere. before you do anything smell the dipstick, you'll see it's cooked
Old Jul 19, 2006 | 03:30 PM
Kemicalburns's Avatar
Kemicalburns
you know Huck i have yet seen a single post were you have offered any decent info. why not find another forum to waste your thoughts on.
Old Jul 19, 2006 | 05:00 PM
HUCKSTER-USA
Yo Chemical ,factory Here Wants To Know If His Tranny Is Dead! I'm Telln Him That It Is Dead And Why It Died. If Your Look For Sombody To Give You Some Kleenex To Wipe The Tears Off Yer Face Yer Talkn To The Wrong Guy! U Folla?
