360 timing
Old Jul 17, 2006 | 06:29 PM
kenarmy's Avatar
kenarmy
360 timing
can any one tell me how to set the timeing on an 1975 ford f-100 with an 360 in it.also can you send me an picture of the correct place to put timming markd.
Old Jul 17, 2006 | 08:30 PM
Mil1ion's Avatar
Mil1ion
Here is the scoop on timing an engine.
http://www.fordmuscle.com/archives/2...ng/index.shtml
You will need a timing light, a 1/2" wrench, a golf tee,a tach and possibly a penetrating fluid.
Timing light = To read the timing indicator and needle
Golf tee = to plug the hose going to the distributor
1/2" wrench = to loosen and then tighten the hold down bolt.
Penetrating fluid = to spray at bottom of dizzy to loosen the strangle-hold the the block has on the distributor.
Tach = to measure the rpm for Timing setting RPMS
Engine timing values for a 75 360 = see decal on valve cover
unioncreek
24
Dec 11, 2019 06:54 PM
The67Beast
Oct 26, 2004 06:53 PM
deane1935
Aug 12, 2003 07:33 AM
JDM1975
Jun 2, 2003 05:18 PM
